Hoover Floormate H3000 Upright Wet/Dry Vacuum
Problem for Hoover Floormate H3000 Upright Wet/Dry Vacuum
Solution does not dispense
By khellick on Nov 05, 2008
the cleaning solution does not dispense but in tiny drips...then not at all. Canister is secure and is full to the appropriate line.
Solution #1
posted on Nov 13, 2008
Not Rated)
n1wgk
Rank: Master
Rating: 94%, 75 votes
The trigger that releases the water is connected by a piece of plastic inside the handle. This plastic tends to bend over time, so it won't press the plunger high enough. I brought it to a vac repair place for the same reason and they added an extension which made all the difference. If I were to do it myself next time, I would look to see if a metal rod were possible to take the place of the plastic. Maybe not, but it would be worth a look.
Was this helpful?
Yes
No
Popular Solutions for Hoover Floormate H3000 Upright
Questions and Unsolved Problems for Hoover Floormate H3000 Upright
Do you recommend Hoover Floormate H3000 Upright Wet/Dry Vacuum?
Answer
Answer
Floormate Wet/Dry Water pours from the clean water reservoir when the machine is tipped back in the... (More)
Answer
I need to clean out the blocked hose on my wet/dry floor mate, please help
Answer
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Newport, KY
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
