Question about Dymo DateMark Date/Time Stamper
Date format changed!
When we came back to work after going back on Standard Time, I changed the time successfully, with help from this website ;-)
However, somewhere along the line, the date jumped from American (mm/dd/yyyy) to English (dd/mm/yyyy), and my co-workers don't like it.
Any assistance would be gratefully appreciated.
  • pdsterling Nov 05, 2008
    I found the answer on p 7 of the user guide!
When all else fails, read the instruction manual carefully
Posted on Nov 07, 2008
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
I just had a representative from the Geek Squad set up my Epson WorkForce 633 Fax/Printer/Copier. The time that we set up is not what I wanted. I want a 12 hour set up, and I need to reset the clock on...
Below you will find the instructions straight out of the manual. I have also put a link to the whole searchable HTML manual at the bottom of this post Enter the Date and Time Before setting the date and time, you should select the appropriate Daylight Saving Time setting for your region. This setting lets you easily set the clock one hour ahead or one hour back when the time change takes place. 1. Press the fax.6.7.1.jpg Setup button. 2. Select Printer Setup. You see this screen: fax.6.7.2.jpg 3. Select Daylight Saving Time. 4. Select Summer if your region uses Daylight Saving Time and it's currently in effect. (DST is effective from spring through summer.) Otherwise select Winter to turn off the setting. Note:
When you change the setting from Winter to Summer, the clock is automatically set ahead by one hour. When you change it from Summer to Winter, the clock is set back. The setting is not automatic; you need to change it each season. 5. Select Date/Time. You see this screen: fax.6.7.3.jpg 6. Select the date format. You see this screen: fax.6.7.4.jpg 7. Use the numeric keypad to change the date, then press OK. fax.6.7.5.jpg 8. Select the time format. fax.6.7.6.jpg 9. Use the numeric keypad to change the time, then press OK. 10. Press fax.6.7.7.jpg Back until you return to the home screen. Epson Work Force 633 Manual Hope this helps. Zeppelinx12
Mar 10, 2011 | Office Equipment & Supplies
How do i change the time and date on my hp officejet 6310 printer
First of all, congrats, you are using one of the best printer on the market.
For HP Officejet 6310 :-
To set the date and time
1. Press Setup.
2. Press 6, and then press 3.
This selects Tools and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
4. Enter the hours and minutes.
5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the display.
And, you can also download it's User Manual from :-
http://h10032.www1.hp.com/ctg/Manual/c00633922.pdf
Sep 19, 2010 | HP Officejet 6310 All-In-One InkJet...
Date
You can set the date and time from the control panel:
1) Press <Menu>
2) Press arrows select "Initial Setup" Press <OK>
3) Press arrows select "Date and Time" Press <OK>
4) Use numbers to enter year - last two digits <OK>
5) Use numbers for month, <OK>
6) Use numbers for day, <OK>
7) Use numbers for time - 24 hour format, press <OK>
8) Press <Stop/Exit> to return to normal function
Feb 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do I reset the clock. After the change to standard time it move up one hour instead of back.
1. Press Setup.
3. Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
The new date and time settings appear on the control panel display.
Nov 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
How reset time?
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
Regards...
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Setting date and time on HP office jet J4580
  2. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Basic Setting , and then
    press OK .
  3. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Date and Time , and then
    press OK .
  4. After Enter
    date
    appears on the control panel display, use the keypad on the control
    panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10).
    After entering the date, press OK .
  5. After Enter
    time
    panel to type the time in the correct two-digit format, HH:MM (10:15), and then
    press the Right (c01185072.jpg ) Arrow button
    to switch between AM and PM . After entering the time, press OK .
Aug 21, 2008 | HP Office Equipment & Supplies
Reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
184 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
