Question about MSI 925XE Neo Platinum-54g Motherboard
Problem with motherboard MSI 925XE
Hi, On building my very first PC, I have done the drastic mistake of screwing it down to the case without the lower washers/nuts (so the motherboard was touching the metal of the case)then plugged it in. I have now refitted the motherboard properly and the computer seems like it is doing everything it should on inside i.e. Fans are going round on case,motherboard (cpu unit) and also on the radeon 1600x 512mb graphic card but i cannot get any sign of life on the monitor. Have i ruined something? please Help. PS Everything is new inside the PC but all was connected when the mistake happened and the monitor works on an other PC.
  • 55 Answers
A couple things: Is the BIOS giving you an error beeps? Also, does the motherboard have Integrated graphics? Sometimes if the Integrated graphics are enabled, it can cause the graphics card to not display at all. You also might want to check that the CPU doesn't have too little or *more likely* too much thermal compound on it. If the thermal compound is on the bridges of the CPU, this can cause the machine to start, but not boot to the BIOS.
Posted on Oct 09, 2006
I need MSI-7312 motherboard drivers for win7 32bit
below is link for this board's specs.
http://msi.com/product/mb/K9MM-V.html#/?div=Detail
However windows 7 is not supported
you can in most cases use the vista driver. or visit each components website for any new support drivers they have.
the above link does describe Realtek as your audio and Lan and VIA as your chipset.
you should at least have the latest BIOS done prior to updating the drivers.
http://msi.com/product/mb/K9MM-V.html#/?div=Driver&os=All
GL
hope this helps
Don
Oct 04, 2011 | MSI K9MM-V Motherboard
I have problems with a new PC build. When computer powers on the screen stays blank. There is no prompt. Case, psupply, and cpu fan all work fine. DVD drive opens and closes. There is no beeps but not sure...
take the battery on the motherboard out. the little disk battery. leave it out for about five minutes. that should reset the bios and cmos to default. also , make sure you plug your monitor into it a default monitor slots on your computer, not to the VGA card if you have one.
Mar 21, 2010 | MSI K9VGM-V Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Continuos beep, No post no screen on 925xe neo. that i'm puting together from spares, I think it maybe a ram issue but before i go out and buy some more want a second opion
Before you buy new memory.
Remove your system memory and clean both sides of the contacts of each DIMM with a drop or two of house hold alcohol onto a cotton swab. Do not touch the contacts after cleaning. Reseat the memory and boot the system.
Your MSI 925XE Neo Platinum uses the Award bios.
Click on the link to open bios beep codes descriptions; http://www.bioscentral.com/beepcodes/awardbeep.htm
The 925XE Neo Platinum MB,
Supports up to 4GB memory size.
Supports Dual channel DDR2 memory architecture.
Supports DDR2, 400/533MHz memory.
You can also test your current memory if you wish. You can download this free testing software; http://www.memtest.org/
Scroll down the site to just below the three screenshots. Memtest86+ V4.00 (22/09/2009).
You can create a bootable CD or floppy disk drive software that will test your current system memory.
Hope you find this helpful!
Cheers!
Mike
Nov 01, 2009 | MSI 925XE NEO PLATINUM - 54G INTEL 925XE...
Soyo KT400L-2AA5 Dragon Lite Motherboard - Lost Bios?
Kinda sounds like a short, have you made sure youre motherboard is screwed in with ground case screws? Ive done this one by mistake and got these same errors, also a fried board after a while. You also need ram in it as well before it will give a display, also if you have a second video car dinstalled you may have the monitor in the wrong video card slot, common mistake. If your bios is hosed then you will need to by a new board if you dont wanna solder a new bios chip to the board
Sep 11, 2009 | Computers & Internet
My Pc off ...
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
auiioo10
Apr 10, 2009 | MSI K8N Neo2-F Motherboard
Foxconn 925xe motherboard
first check wheather power cable is join correcly at the monitor
then check video card placed correcly in agp card
or see the monitor cable join correctly at pc
Dec 07, 2007 | Computers & Internet
Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI K8MM-V Motherboard
MSI 925XE Neo Platinum-54g Motherboard Logo
67 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Davit Mamyan
Davit Mamyan
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
