Question about Denon DN-2600F CD Player
Older Denon DN-2000F vintage setup problem on right side CD player
I have several of these DJ CD players and always have disk setup problems on the right side CD player in the units.
I have personally replaced lasers in some of the units, but they only seem to cure the problem for a short time and then the problem reappears.
Any idea what causes the problem?
  • natere2ster Dec 03, 2008
    not sure how these things work but i put a cd in both sides and dont hear them spinning....the unit powers on ok....
    i think they are out of alignment but i dont know h ow to service them, looking for the service notes as I type! wish me luck!
SOURCE: Denon DN-951FA
Push your "track selector knob" IN towards the unit and hold it in while pressing and releasing your STDBY/CUE button. This resets the microprocessor (kinda like rebooting) the unit. If you want to speak to me further about your 951fa, email me at chris at cueblip dot com Thanks!
Posted on May 06, 2007
robotek
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
Posted on Feb 20, 2009
projdoc
  • 2237 Answers
SOURCE: hello i have a denon dn-650f cd player and i need
it's called an optical pickup and try mcm electronics. www.mcmelectronics.com
Posted on Dec 14, 2009
Testimonial: "thanks very much"
Denon troubleshooting
sound like you have changed your burning format and your player does not support that format trying using a different format to burn your songs your player should say what formats it supports like wmp mp3 ect good luck
May 03, 2014 | Audio Players & Recorders
Need the firmware to upgrade denon dn-hd2500 they say to go to denon dj .com but only lameness
send me your e-mail address and I will upload the final version firmware update! Ver. 1400
Feb 29, 2012 | Denon DN-HD2500 MP3 Player
My jog wheel on denon dn s1000 is messsing up will not work properly
The encoder probably has dirt or dust in the pickup. Remove the wheel and clean the sensor area.
Aug 05, 2011 | Denon DN S1000 Scratch DJ Table Top DJ CD...
The play button on my denon DN s 1000 has fallen of and i have lost it, where would i get a replacement?
Most of these buttons are special and can only be obtained through the origianl manufacturer. You can search Digikey.com and might get lucky... it is unlikely you will find one with the right legend on it... but at least you would have the button.
May 02, 2011 | Denon DN S1000 Scratch DJ Table Top DJ CD...
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
HI HOW DO YOU CLEAN THE DENON DN-S5000
Let me start out by saying what not to use: Don't use the cleaning CDs that you can buy. Most of those have tiny brushes on them that could scratch the optics inside your CD player and make things worse. Your Denon CD player and similar pro grade DJ CD decks are a higher precision player than the average consumer CD player that those things are marketed towards.
Your solutions are these:
  1. Find a vacuum cleaner with decent suction and use the hose attachment remove any dust or other debris that may be lodged inside the player by running the hose around the entire player (you'd be surprised where dust can lodge (and from where it can be dislodged).
  2. You can use canned air... but two caveats: Canned air doesn't necessarily move the debris and occasionally when spraying it, you get bursts of moisture with the air. Obviously moisture inside your playe would be a bad thing.
  3. Take your player to a reputable electronics repair facility and have it professionally cleaned and the optics adjusted.
I keep a microfibre cloth with me in the DJ booth and look at every CD before I put it inside my players (I have DN-S3500s) and if there's any grime, I use the cloth to remove it.
Dec 21, 2008 | Denon Dns1000 Table Top CD Player CD...
READING CD'S
well maybe it needs to change the optical lens now. but try to adjust the variable resistor at the optical lens. I don't know if its turn to left or right.
Feb 07, 2008 | Denon DN-2600F CD Player
Dual cd player
one side of my denon 2600f cd player will not read a disk. What can I do
Aug 31, 2007 | Denon DN-2600F CD Player
244 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
