Question about Gaggia Tebe Espresso Machine
No cream on the espresso when dispensed
I have a question. Our gaggia tebe has been maintained through the years. What is happening now, when the coffee is dispensed from the machine, there is no cream on the espresso coffee in the cup. We buy very good coffee beans but the taste is not robust. It seems weak tasting. Can you help me out with any suggestions? We hand grind the coffee and tried fine to medium grind with no success.
  • fixmycoffee Nov 06, 2008
    Thanks for the input. Today, water starting leaking where you engage the handle with the coffee to the machine. The coffee was discharging and mixing with the leaking water. I'm thinking maybe a seal or valve may need to be replaced. What's funny, is we are actually using Lavazza beans. I'II check out James.
  • Anonymous Mar 24, 2014
    placing the espresso nto the contaionor and pressing the power button on and then espresso button. the coffee squirts out all over my kitchen before it drips into the cup a big mess
  • 3 Answers
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Posted on Nov 06, 2008
Hello! my 102534 gaggia esppresso machine has liquid/espresso dispensing after the 'espresso dispenser' has been turned off. if i turn the entire unit off, it does eventually stop. i've have...
HI JULIE,....MAKE SURE YOU ARE NOT FILLING THE WATER DISPENSER PAST IT'S OVER-FLOW...THERE IS A HOLE TOWARDS THE TOP...YOU DO NOT WANT TO FILL PAST.
HOPE THIS HELPS!
Sep 03, 2011 | Gaggia 102534 Espresso-Color...
Too much water is dispensed resutling in a weak espresso. This happened after rinsing the brew unit. Greatful for any assistance with this. I have a 1 year old Titanium.
Hi
Try reprogramming the button that is dispensing to much.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Jul 20, 2010 | Gaggia Titanium Espresso Machine
Steamer not working &steam coming out where coffee normaly comes out.
check solonoid valve,usually valve is clogged!you need open top,after you will see coil and valve,remove coil and you need open valve and clean!
Mar 08, 2010 | Gaggia Tebe Espresso Machine
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Coffe only drips out, no pressure?! Sometimes works ok...
Make sure the basket has a good seal and it is tightened on.
Oct 20, 2009 | Gaggia Tebe Espresso Machine
Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Apr 03, 2009 | Gaggia Carezza Espresso Machine
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Tebe Espresso Machine Logo
283 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
