Question about Sharp UX 108 Roll paper Thermal Fax
Sharp UX 112 FAX Mirrors
My incoming FAX Transmissions are fine.
My out-going FAXs are received with the left and right margins compromised abpout 1/2" to 3/4" in, and I am told the reflective mirror has accumulated dust on it along the edges. This also holds true if I put an original through under the "Copy" function, It is not abl;e to read the edges.
How do I cleans the dust off the appropriate surface?
  • Vermont007 Nov 06, 2008
    We have tried that several times BEFORE posting this question. I think we need to get to the underside of the scanner glass to clean it, even though it looks clean to the human eye. Is there a simple procedure for removing the scanner glass ?
  • Vermont007 Sep 20, 2010
    I finally bought myself a PDF copy of the Service Manual (98 pages) and carefully disassembled the Unit down to where I could remove the whole Optical Unit and clean the three (3) mirrors with de-natured alcohol. Loads of dust had accumulated. Now it's back to working just like new. I'd never have had the confidence to rip it apart without that Manual . . . . it was money well spent.
  • 318 Answers
Try to clean the scanner glass and the upper white strip(the white plastic strip just above the scanner) with spiritus.
Let me know
Posted on Nov 06, 2008
    I broke down and bought a PDF Service Manual (98 Pages) which gave me the confidence to disassemble the Unit down to the point where I could remove the Optical Unit and examine the Mirrors (3). There was an abundance of dust accumulated which I vacuumed off and then washed the mirrors with denatured alcohol. Upon re-assembly, it now works like new. We use the traditional FAX less and less; but it would be a shame to dispose of it simply for being dirty, when it has much useful life left in it. Without that Manual, I would never have had the confidence to rip that thing apart . . . . so it was money well spent.
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Fax
You probably need new ink / drum / toner.
Oct 13, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Receiving fax
your fax machine set to auto mode with the help of receive mode button of machine, this setting will give you automatic faxes.
Apr 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
How to Clear Memory in Sharp Fax UX P115
call sharp tech support (905 568 7140) for instr. they are very helpful and will guide you thro' the deleting memory process in madel ux-p115.
thanks
lk
Apr 11, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Sharp fax machine
Please help. Can Sharp UX-BD90 tel/fax machine be set to mute incoming calls?
Thankyou.
Jan 07, 2008 | Office Equipment & Supplies
Fax Machine is a UX-104
You have a problem in your Scanner Unit.Try to change New Paper Separator so that when you send out it will not be shrunk again.
Aug 12, 2007 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX 108 Roll paper Thermal Fax Logo
248 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
