Question about Kenmore 24902 Top Load Washer
Water after spin cycle
I have an 8 year old 80 series Kenmore -- It really began to smell - took it apart checked hoses - cleaned lots of residue off of plastic tub and bottom of metal tub - my question is this - - after the finall spin cycle we can still here water in the plastic tub adn see some thru the holes of the metal tub - - Is this normal or do we have a drainage problem Thanks.
  • 640 Answers
Remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Posted on Dec 24, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Mold in Kenmore Series 80 washer
You most likely have mold/crud on the top outer edge of the drum and even the tub it sits in from years of soap and water splashing up and sticking, The cleaners probably cannot reach those areas, You will have to take off the cabinet and clean all that off (should be videos on YT on how to take it apart)
May 03, 2017 | Kenmore Washing Machines
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series makes buzzing noise but won't drain or spin, smells like burning if left on spin cycle.
That sound a lot to me like yall have something inside the pump. Over the years I have found all kind of things from ladies undergarments to shoes strings. themobilian_1938.jpg
Video pump replacement:
Service manual
Mar 16, 2011 | Washing Machines
Smells like something is burnt but dryer works fine
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Kenmore Dryers
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Kenmore series 80 12 years old
hey thats eazy.your washer has a water fill valve.the two black hoses go to it in the back.inside the valve where the hoses attach their are screens that keep minerals from going into the water valve.also some have screens on the other side off hose too,and after cleaning run the water thru the hose into the drain/sink because minerals may be backed up in house line or hose.If dosent improve after this its in your water valve and theres nothing you can do but replace the water valve they dont come apart for cleaning,or could take apart but looking for trouble because wont then seal and will over flow on to can do it .God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Water not draining
check if anything is blocking the way of the drain pump ...else the drain impellor would have broken...
Dec 05, 2008 | Washing Machines
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore 24902 Top Load Washer Logo
113 people viewed this question
Sal De
 Brian Main
Brian Main
