Question about CTX (MD001) Video Capture
Not recording i install the card and the drivers. I see the TV on the computer but when I press record nothing happens...
0 characters
1 Points
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | TV Accessories
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
Not install software SAA7130 TV Card Please Help me for your download software. thank you
I have a honestech TVR Tuner card (Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture) on my *other* computer. I can watch tv no problem, i see stuff, and there's audio. But when i record, i can only record image, no sound. It asking for digital singh and not instaling praperly
Aug 03, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have Mercury's TV card with Philips7130HL Chipset, I found proble with Recording and sound, sound with card is working but on the time of recording Sound was missing, kindly assist me how can i get sound...
Hi! if you have windows XP then try to find another software for your card, NOT DRIVER! the problem is in the software which made the recording. I had that problem too along time ago and I bough a new card for me to save my nerve cells... :-)
Dec 24, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problem in recording and using the remote
this is only a wild guess, change the battery of your remote, i once use a tv tunner and the only problem is the battery from the remote
Sep 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
How can I record from VHS to Computer with Sabrent TV Tuner?
Did you install the driver for the remote control?
In either case, the video will automatically start playing on your computer but not recording. You can just click on the record icon without using the remote.
It sets up a folder under your Documents. It should then show you the icon so you can name the file.
I am having the same issue with the sound though. Haven't yet solved it. Will post the solution if found
Feb 16, 2009 | Sabrent TV Tuner / Video Capture Box USB...
No Sound in Vista
Go to this link:
download the file.
Execute the given file on your hard disk and copy the location to driver vista from the address bar.
1. Go to run and type "devmgmt.msc" without the quotes and press enter.
2. In the device manager window select your SAA7130 card. (it should be in the sound and video categorie).
3. Right click it and go to properties.
3. In the properties click update driver software.
4. Select browse in my computer.
5. Paste the location to driver vista here.
6. Click yes on the messages.
7. Install SuperTv pro.
8. Enjoy!
Dec 23, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Software Driver This link is for TV viewing... 2) I recommend you VIEW tv with the Lifeviewer application, however CAPTURE with WinDVR (which came with the TV program, just select recording quality to bestest).
Nov 29, 2007 | Philips TV Tuner Video Capture PCI Card -...
Hi, try reloading your audio drivers first. If this is on board sound the drivers will be on the disk supplied with the system.
XP will also detect and run most onboard sound. If you have nl luck with the drivers then install a PCIE sound card, they are inexpensive and simple to install.
Regards mistyman
Oct 10, 2007 | Leadtek WinFast TV2000 XP Expert...
No sound when recording
Well, looks like you went through all the steps, but I'm wondering about one thing... If you goto: Start -> Control Panel -> Sound and Audio devices There are 5 tabs at the top, 2 of which you'll be paying attention to "audio" and "voice". On these tabs are the record settings, which you will want to have the drivers for the m-audio in the record processes. For instance, I have 4 options in the record process: Logitech (mic built into camera) SoundMax (sound card) Bluetooth Audio (bluetooth server) BlueTooth High quality audio (bluetooth server) Out of the 4, I have logitech enabled in the record area (which isn't the right thing as the camera doesn't work anymore...jeez, found something that I need to fix on my PC now...)
Mar 11, 2007 | KWorld DV/AV Expert TV Stereo...
CTX (MD001) Video Capture Logo
15 people viewed this question
Top CTX TV Accessories Experts
Brian Sullivan
Brian Sullivan
Are you a CTX TV Accessory Expert? Answer questions, earn points and help others
