Question about MSI Computers & Internet
Msi neo3 fails to start up,when xp asked to restart pc,fans and lights come on,but it dosnt boot up,i have 2gb ram and a sata 160gb,and a gtx 280 grahic card
  • 1 more comment
  • zxrrxp Nov 05, 2008
    its a intel 8600 core,2gb 1066 ram 160gb sata hard drive,a bfg gtx280 670 core speed 1 gb ddr3 ram
    re seating ram dosnt help,not taking out graphic card and re seating it to
  • zxrrxp Nov 06, 2008
    I Already done all that aswell,im not exactly a learner on a pc,i know all the ins and outs of it all,no thunder storm or lightning,pc starts up ok,but every time ya tell xp pro to restart,it does,then hangs,with fans and lights going,but dosnt boot,pressing rerset buton it then boots ok.but restart it dosnt want to know,flashed all the bios many times from 1st to the new,it keeps doing it.msi neo3 board with 850watt psu 2x1gb crucial 1066 ram bfg gtx280 670 core.1gb ddr3 ram.Ive been all over the net,and others have same problem with diff set ups,its a motherboard fault,ive even been intouch with msi,but they dont know sh-t.Its not a one off,others have same problem to
  • zxrrxp Nov 09, 2008
    Ok i found out the problem fix with my msi motherboard.In the bios there are 2 options "fail safe load" or "high specs mode".you load in the fail safe mode,save and reboot.After it has rebooted restart pc,and go back into bios.Do it back to all your settings,and save.Now when you restart it does,and just dosnt hang.So obvious a bug in there somewhere.But problem solved.
    Sergeant:
    Champion:
  • 275 Answers
No display ?
try reseating the memory card and the graphic card
and than start the system and also tell me if that worked or not ... what computer u have ?
Posted on Nov 05, 2008
  • Ali Khambati
    Ali Khambati Nov 05, 2008
    try 2 more steps
    one remove the cmos battery and than start the system see if that takes care of it or not
    two disconnect the power cable from the tower and hold down the power button and hold it down for 10 seconds and than connect power again and try
    by any chances did you have a thunder strom or lightning ?
  • Ali Khambati
    Ali Khambati Nov 08, 2008
    if i am not mistaken u have a usb printer connected ... am i right ?
MSI 945P Neo3 motherboard not starting, no beeps, no video, just black screen
remove and clean by an eraser the video card, memory card inserted in the motherboard and put it back one by one and test the computer.
Aug 01, 2011 | MSI 945P Neo3-F (7236-040(945P NEO3-F))...
Hello! My MSI 945P Neo3-F MB refuse to find all 4 Gb of RAM. I have two modules of 2 GB each. MB "see" only 3.2 GB. Help me, please.
if you are using an 32 bit operating system you system will part of your memory a cache when you use 2gb or more. you may want to upgrade to a 64 bit operating system
Feb 01, 2011 | MSI 945P Neo3-F (7236-040(945P NEO3-F))...
Pc wont boot up, the led lights 1and 2 on D-bracket 2 blink green but 3 and 4 for are red. the monitor wont turn on either
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Oct 22, 2010 | MSI 865PE Neo3-F Intel 865PE LGA775 DDR...
Whats the best graphics card for msi 865pe that i can install?
It depends on your power supplie processor and ram.
id go with a 1000w powersupply
at least 8gb of ram
3.0 Quad Core processor
then slap x2 GeForce GTX 295 CO-OP Edition
Mar 06, 2010 | MSI 865PE Neo3-FS Motherboard
Asus X51RL laptop, vista, xp
you can not downgrade from vista to xp on almost any computer without replacing many components...Ethernet video sound and more
Sep 05, 2009 | Computers & Internet
Problem install windows xp using SATA hard disk
Can you inset fdisk using floppy or cd rom. it will open comment prompt. select the partition tab Delete the C partition and create partition and boot again.and and install the os package. if you have any doubt please make me mail....i will send screen shot to you. Via mail me at javidjeff@gmail.com
Jul 02, 2008 | Microsoft Windows XP Professional for PC
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
How to configure my MSI 865PE Neo3-F and Install an Operating System?
Check your Hard Drive with diagnostic software.
Test your memory with diagnostic software.
Been using this board with Windows XP for over a year with no problems at all.
Jan 15, 2008 | MSI 865PE Neo3-F Intel 865PE LGA775 DDR...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
70 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
