Question about Neff 24 in. S5456 Built-in Dishwasher
NEFF DISHWASHER S5443 STUCK IN TEST MODE
I think our 5 year old Neff is stuck in test mode. This is entered by holding all 3 programme buttons and powering on. Certain combinations then cause the pump to run even with door open. All lamps lit.
How do I exit this and get back to normal programme?
Main problem is that cannot select programme at start of programme. None of the lights work.
dave
  • davie p Nov 06, 2008
    Will,
    Tried 90 mins off at mains: no joy.
    Opened front case and removed board but no sign of reset or battery.
    I am convinced there is a combination of buttons to perform various tests, and presumably a way of reseting via this...........
    Any help would be great. I will leave power off overnight as well.
    dave
    Scholar:
  • 68 Answers
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Posted on Nov 05, 2008
Can I plumb a s5443 into a Hot water supply.
Thats the only line you need to install dishwasher,you need the hot line and not a cold,the hot is for the heat that is needed to thoroughly clean the dishes.
Oct 16, 2012 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a s5443 neff dishwasher no lights coming on and nothing happening. fuses ok in scockets
could be your mains surpressor or main board on the appliance. check for continuity from the plug to the board if you have it then it is not the surpressor it will be the board. if it is the board you need to find what part has caused the board to blow
hope this helps
Nov 11, 2011 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher S5443 is not filling with water
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 15, 2010 | Neff Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
What does error code e68 mean
One of the buttons is stuck closed or shorted. Enter the function test mode and perform the button test to determine which button is stuck or shorted. When determined which button, try to free or unstuck the button then perform the test again. Replace the user interface board when the button is freed but the code still exists.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to reset the control. When resetting is successful, the buzzer will sound and "rES" will be shown briefly in the display, and then immediately rotate the cycle selector knob 5 turns in the counterclockwise direction to the second position from the bottom.
Press and hold the OPTIONS and CANCEL buttons simultaneously for 2 seconds to enter test mode; the buzzer will sound 3 times and all of the LEDs will flash rapidly.
Rotate the cycle selector knob 4 times in the clockwise direction to enter button test. Press the buttons one at a time and observe the LEDs corresponding to that button light up. The LEDs should light up; otherwise the button is stuck.
Press and hold the SELECT and CANCEL buttons simultaneously for 6 seconds to exit test mode.
Apr 04, 2010 | Frigidaire Electric Dryer
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff Built in Dishwasher
take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Jun 26, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
1,641 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
