Question about Sony Cyber-shot DSC-H7 Digital Camera
Hi thank you so much
When i turn on the camera i push the button which is written ``home`` and than i entered the ``settings`` after there is a options of ``main settings`` inside of the main settings there are three options
# beep
# function guide
# initialize
i choose the 3rd options. it asked me initialize all settigs
i choosed ``yes``
after that processing clock settings comes to screen i set the time and date...
the first time it worked but as i said after a couple weeks later when i had the same problem which is e:91:01
thank you so muchnow i was trying this and during the initializing the battery finished. and i change the battery after i didnt set time and date
i just click the button which is yes.
i tried to take a foto it works
thank you so much
and more information I`m from Turkey i was working in MA during the summer. i bought that camera and when i see the warranty it says you can use only in usa
so i think that in other country sony will not repair that for free.
thank you so much again...
    Novelist:
  • 208 Answers
I AM GLAD THAT I WAS ABLE TO HELP YOU. IT WAS A PLEASURE WORKING ON YOUR PROBLEM AND WORKING TO CORRECT IT. PLEASE FEEL FREE TO REPLY ANYTIME YOU NEED HELP!
ARCLIGHT1217
Posted on Nov 05, 2008
How to calculate standard deviation
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
Sep 23, 2011 | Texas Instruments TI-84 Plus Silver...
How do I make an LG DR386D DVD player region free
hi,
make your player region free by the following simple setting.
p { margin-bottom: 0.21cm; }
1.Press Home button
2.Press SETUP
3.Select Padlock Picture (4th Down)
"Do not enter the menu just stay on the padlock picture"
4. Push 0 seven times
A message will say Region Free mode entered Push Yes (enter button)
ok
Jan 18, 2011 | LG Televison & Video
After replacing the magenta and cyan drum units the machine power off and shuts down while idle
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Please perform these troubleshooting steps as mentioned:
Turn machine on while pushing and holding the (+/-) menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Press (- or +) button until (“ENGINE = PARAMETER SET 2”) is displayed.
6. Push Enter button
7. "TONER SENSOR = ENABLE" is displayed.
8. Push Enter button
9. Press (- or +) "TONER SENSOR = DESABLE" is displayed.
10. press "ON-LINE/CANCEL" buttons at same time.
11. (*) is displayed.
12..... READY
Thanks for contacting Fixya and please accept the solution if it has helped you.
Mar 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi.I've a canon mp110. on display there's written ''bottom ink absorber is almost full''. I cleaned and changed colours but there's no solution. please help me, thanks
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service mode.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
Oct 27, 2009 | Canon Office Equipment & Supplies
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
SONY DSC-W300 macro will not turn on
Looks camera requires RESET (Initialize) by following procedure.. Press HOME >> Settings >> Main Settings 1 >> Initialize >> OK and and enable Macro.
Jun 10, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Iphone wont start after software reset
Try the reboot sequence that you can initiate from the phone buttons. You can find it in the iphone support on the apple site, but I believe you push down the top right button (on/off) and hold it down while you depress and hold down the "home" button (round button-bottom front center). After, I believe< either 15 or 30 seconds it should turn off and then back-on(reboot)....then you can release the buttons.
Sam Bass
Nov 15, 2008 | Apple iPhone Smartphone
Camera won't push lens out when turned on
there was a button on top of the camera, the one that sets the settings, that was in the wrong place. I just changed it and the camera works. Thank!
Sep 21, 2008 | Kodak EasyShare Z1275 Digital Camera
90 sec count down
You Can Turn off the panel beep under the cover that is what i did.
Apr 15, 2008 | GE Security Simon 3 Wireless Home Security...
Sony Cyber-shot  DSC-H7 Digital Camera Logo
56 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
