TM230 M2132 - screen problems. ctrl-Fn-F6 gets it back but only for 5 sec.
Acer Travelmate 230, M2132 - screen comes on then goes to a shadow type. Pressing ctrl-Fn-F6 gets the screen back to full bright view, but it only stays thate way for 5-10 seconds.
  • bob_sabo Nov 05, 2008
    same thing - no change . also , the person who gave me the "remove the battery" suggestion; that didn't work either
  • bob_sabo Nov 06, 2008
    the laptop screen does the same thing in safe mode as it does when running regular mode. cuts out after 5 seconds. The only place it doesn't is on the external monitor.
I Have Exactky the same Problem and still Looking for a solution your the only person i have seen with the EXACT! same problem
Posted on Jun 17, 2009
Hi techniwiz -- update: i did the un-instal then re-instal in safe mode & there was no change. HOWEver - when i plug in an external monitor the problem does not exixt on the external but still exists on the laptop.
the other thing is, that i have to jiggle the external plug to get it to work
Posted on Nov 05, 2008
    Sergeant:
    Champion:
  • 275 Answers
Go in the safe mode and than uninstall the graphic driver and restart the system and again install the driver again and in case that happenes again chk with a known good monitor and tell me the results
  • Ali Khambati
    Ali Khambati Nov 06, 2008
    that means the the system is working good ... the only part which is creating an issue is the display
    you did not tell me that does the system do the same in safe mode with the laptop screen or it allows you to work around
  • Ali Khambati
    Ali Khambati Nov 08, 2008
    there could be a hardware issue so plz call the technical dept of the mfg of ur computer
How do I adjust the screen brightness on my acer travelmate 2400
  1. Hold down the Fn key located at bottom left of your keyboard next to the Ctrl key.
  2. Adjust the screen brightness using the up and down arrow keys located near the bottom right corner of the keyboard.
Nov 14, 2012 | Acer TravelMate 2400 Series Laptop Charger...
I have the acer aspire 5536-5112 black screen
I solve this using Fn + F6, using a 5536 model. Just press Fn + F6, keep holding it and hit the power button, wait for about 5 or 7 seconds, release the Fn and F6 keys. thank you so much guys!
Oct 19, 2012 | Acer Aspire Computers & Internet
Acer travelmate 5320
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Acer Computers & Internet
Model acer travelmate 4000 nodisplay on lcd and external monitor
You say the trouble is with the keyboard. Can you attach an external keyboard via USB and see if you can push Fn key with F5 (I think it is the F5 key - try Fn with others - keep Fn pressed and repeatedly press the F5 or F6 etc.) several times to see if the screen toggles between LCD and external monitor. For this to work you will have to restart the computer after attaching the external keyboard. Press the start button until the computer goes off, and press again to restart.
Itf you ascertain that the trouble is with the 99.N7082.01D, make sure to try to fit it in correctly, or perhaps the Fn key has some dust or liquid in it so it does not function. Then you have to try to clean it from the inside after you disassemble.
Jan 07, 2011 | Acer TravelMate 2300 Notebook
Screen goes black, turn it on with fn+f6 but goes black again after 2 secs
right click on the screen, go to properties, screen saver, power settings, and set turn off monitor to desired setting. If that is not the problem then there might be a loose connector inside the pc. or another thing could be that the screen itself is failing but hopefully its not.
Apr 13, 2010 | Acer Aspire 8920-6048 Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Have a acer aspire 5570 2067 that was dropped and the screen was broken. how do I hook it up to an exterior monitor.
Look at the back of your acer you will be having a blue monitor port or a white,the same should be there at the back of your monitor as well,now one get the cable for the port that your monitor and acer has common.A blue or a white once you connect the monitor and the Acer press this key combination
Fn+F6 .Fn key is the one betwen on the ctrl key and the window key on the keyboard on the left bottom of the keyboard.
May 27, 2008 | Toshiba Satellite A135 Notebook
I think you're trying to output the screen to external monitor right ? So when you press Fn+F6 this will output to external monitor only but if you do it again it will output to both (External and you LCD) and if you repeat the step again you're back to normal.
goodluck,takecare.
May 24, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
