Question about RCA VR612HF VCR
Problem playing I put a tape in andpush play, but all I get is a blue screen. when I fast forward or rewind i see the movie but when I press play again I get the blue screen again
    Problem Solver:
  • 4 Answers
Parkersmom:
Try setting the TV to channel 3 while you play the tape and see if tha works... are you the same ps mom who posts on the soap boards? OSF
Posted on Jan 25, 2009
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
