Question about Refrigerators
My Beaumark Bottom Freezer Refrigerator Top Compartment (refrigerator Part) doesn't work
  • linysik Nov 05, 2008
    The refrigerator compartment doesn't keep the cold. However the bottom part (freezer) is working. It has been happening for 3 days. We try to put the frozen food from the freezer to the refrigerator to cool a bit the fridge. It is getting worm again upon defrosting the frozen products. Please help!!!
    Genius:
  • 2,035 Answers
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets...
Good luck...
Posted on Nov 05, 2008
    Brigadier General:
  • 6,966 Answers
In most cases such as what you have described, the main issue is that not enough cold air is being drawn to the refrigerator side. This could be caused by:
  • evaporator fan failing to spin to speed;
  • blocked air passage way;
  • blocked cold air ports/vents;
  • defective thermostat of the refrigerator side;
  • too much food in the refrigerator;
  • some of the food stuff are blocking the air flow;
  • the compressor is cutting out early.
Please observe and do a visual inspection. You may find any of the above applicable to your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Guru:
  • 558 Answers
Its gas is need to refill and check for the Condenser
A liquid coolant (known gas) is circulated through these coils by a compressor and a motor. If the freezes not making ice it obviously fault by Conderser coil in the freeze.
My Beaumark Bottom Freezer Refrigerator - how-to-repair-a-refrigerator-1.jpg
  • Puneet Jain
    Puneet Jain Nov 05, 2008
    See this pic showing its part and name to help you in locating the fault, i advised you earlier.
    Genius:
  • 1,124 Answers
Probably you have an issue related to your freezer thermostate
    Scholar:
  • 155 Answers
Defrost the fridge for 24 hours and then adjust all the temprature settings again.and then try.
2 Suggested Answers
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Posted on Nov 06, 2008
Water collects in refrigerator which is below freezer
use air from bottom of fridge, but you will have to clear top drain eventually
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
Drain water freezes in the back of the freezer compartment and no cold air gets to the bottom compartment.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Whirlpool ET1MHKXM Top Freezer...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm refrigerator compartment
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Jun 21, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
tresilla
Nov 05, 2008 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Water present in refrigerator compartment
probable cause is the defrost element in the bottom of the freezer compartment allowing ice to build probable need to replace defrost element
Oct 11, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
