Question about EnGenius Computers & Internet
Problem EnGenius ECB-3610s
Good morning, I have ECB-3610- 1.0.1.02 formed like AP, I have 10 clients and the response time is put unstable is put highest and packages are lost. the AP this to a distance of 800 mts. of the clients with an antenna of 24 db. It is blocked and it been called on to reinitiate the equipment so that it works again. Agradesco very enormously the aid that can offer me. Kindly; Orlando Marin Colombia
orlams@yahoo.com - orlams@hotmail.com
  • 78 Answers
I had the same problem, now i have none...............
how?
login to....
http://primustel.blogspot.com
and find out how............ Check out the ONSPEED banner
and also run a PING TEST. Good Luck
WAS I HELPFUL?
Posted on Nov 17, 2008
Reset ecb3220
Call you local dealer thay sould walk you thur it
Jan 22, 2015 | EnGenius Wireless Lan Long Range...
How do I setup port forwarding (UPnP) on and EnGenius ECB-3500?
https://www.radiolabs.com/downloads/manuals/Product%20Manuals/RL3022AP-User-Manual.pdf. Also this>>https://www.youtube.com/watch?v=c-YomYxZMoU
Mar 06, 2014 | EnGenius ECB3500 - wireless access point...
I'm trying to connect the ecb3500 as an AP Router to get wireless access from my cable modem. THe old LinkSys worked fine, although it has low power, but the ecb is unable to connect (status of connection...
ECB3500 Can I downgrade firmware safely with this product?Yes. I cannot get into the device from my computer. What is the basic setting check?
- Make sure you are directly connected to the unit.
- Do not have a switch or router in between and do not connect wirelessly.
- Make sure your power injector/adapter is on, power is going to the unit, and the "network" side is going to your computer.
- Make sure your computer is set to a static IP address of 192.168.1.10.
- Type in 192.168.1.1 using Internet Explorer.
How to change the IP Address?
The default IP address is 192.168.1.1. This IP address is typically in conflict with many routers out in the market. You will need to change the IP address manually to an IP address that is different but part of the same network. This means if your router IP address is 192.168.1.1, you should change the device to 192.168.1.2, for example. We recommend you change the IP address before other settings. You change your IP address in the "LAN" section in the GUI.
How do I reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
How do I set up AP WDS Repeater?
Click here for instructions.
How do I set up the device under Apple MAC OS X environment?
I cannot connect or maintain a log in to the device.
We recommend using internet explorer with at least IE7 or higher. Make sure you have latest version of Java script.
What distance in kilometers (km) should I set the device to?
Default is 1km. If you are setting up long distance point to point links, the time it takes the radio wave to get there needs to be considered for proper handshaking (ACK response). This window should be accurate within 5 kilometers. In other words if you have a 5 kilometer link, ideally you should set it to 5km, but a setting of 1km to 10km should keep you in an acceptable window. For short distances, keep this to 1km.
What is a point-to-point link setup?One unit would need to be in AP mode while the other in CB mode. The AP should be connected directly to the routers LAN port, and the other will be in Client Bridge Mode linking back to the AP. The Client side will then provide a WIRED connection for users of the remote location. You can choose to connect this wired connection to just one PC, or to a switch, hub, or another wireless access point for multiple users at the remote location. What is a Client Bridge (CB) Mode?
A client connects to an access point. Your laptop is a client. A bridge is something that connects two "wired" networks together. A client bridge therefore is a radio that wirelessly bridges two networks. The Ethernet port of the 2610 in CB mode provides the wired connection to the remote location. This Ethernet port can directly connect to a single PC, a hub, a switch, or another router.
What is considered a "good" signal?The signal meter is not available in AP mode. In CB mode, under connection status, a signal of -74dbm or better is a good signal. It's important to understand which direction numerically is a better signal. Dbm's are referenced to 1 milliwatt. 1mW = 0dbm. A stronger signal would be a positive number and a weak signal would be a very negative number. For example, a -50dbm signal is stronger signal than -92dbm. What is spanning tree protocol?
When there are several possible paths a packet can route to (redundant links for increased reliability for example), a loop can occur (jamming up the network). It is used to prevent these loops.
What is the default gateway?The default gateway is your router's IP address. The default gateway information is not required, but is recommended.What is the default user name and password to log into this device?
Log in name is "admin" and password is "admin" by default.
What is WDS Mode?Stands for Wireless Distribution System. Allows access points to link together and provide repeating. Note however, this repeating comes at a cost of reduced bandwidth. Bandwidth will be reduced by 30-40%, and it is recommended that NO multiple repeating hops be done for this reason. Which antenna connector is the primary antenna?The one closer to the power jack.
Jan 06, 2011 | EnGenius Technologies ECB3500 802.11g High...
I just installed a new ECB-3500. It works fine on
Connect your Lenovo to the ECB with a standard Ethernet cable. Assure yourself that it can talk to the internet in this configuration. If it works, it will rule out DNS and DHCP issues and will point to a wireless-only issue.
Temporarily turn off encryption on your router and see if your Lenovo can connect. If it does, turn on WEP encryption only. If that also works, go back to WPA. Wherever the process breaks down, it will tell you where your problem lies.
May 17, 2010 | EnGenius Technologies ECB3500 802.11g High...
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
"sorry this site can not to access"
Try a reboot of PC & a Power OFF reset on AP. try another browser, clear out cache & cookies.
Mar 07, 2010 | EnGenius ECB-3220
Comando para ver clientes conectados
After logging into the EOC-3220 with Telnet, enter:
cat /proc/wlan0/sta_info
Mar 20, 2008 | EnGenius EOC-3220 (EOC3220)
Ecb-8610 reset itself
It could the the hold and store capacitor going bad. This would cause the flash memory to corrupt and drop back to a default configuration.
Sep 10, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
Loses connectivity
Hi, a couple of ideas: 1. maybe out of range or too many obstruction, how far is the client from the AP or are there any objects in between. it's gotta be line of sight; 2. with 200mW power output and 5dBi external antenna, should be adequate, if not maybe slightly directional performance (no longer perfect omni). try rotating the device and more or less guesstimate max signal at a particular orientation (pointed towards the client). Netstumbler would be good enough for signal strength; 3. consider the optional integrated 9dBi patch antenna; 4. for the client having a hard time with the AP, manually enter the TCP/IP settings and not auto obtain. numbers should of course match AP settings except for the last digit(s) of the IP add; 5. try moving the client away from any RFI sources like cordless/wireless phones, microwave ovens and others; 6. at one time, signal strength to a client improved by moving the AP a couple of feet away from the original installation point. of course if your unit is mast mounted, then you have to move the mast as well or put up a new one. Hope this works for you. Good luck and pls post again how things turn up.
May 24, 2007 | EnGenius EL-2611CB5+ (NL2611CB5)
Computers & Internet Logo
854 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
