Question about Canon PIXMA iP1800 InkJet Photo Printer
Problem with my color
I never use color, only black and white. Yet I am having to replace my color cartridge because the printer says I'm low on color. I replaced my last black cartridge on 9/26/08 and color 9/9/08. My black cartridge is 1/2 full but shows color empty. Grrrr. Please help me. I've called Canon about this and they don't know what to tell me to do. (Do I have a lemon?) I bought it on 3/22/07 and was installed by a paid computer tech.
How do i find the link to install the program to fool the printer??
Posted on Nov 13, 2008
    Brigadier General:
  • 6,966 Answers
My apologies for a late reply. Your concern was just brought to my attention. Your printer is not a lemon. It actually is a very good and dependable printer. However to be good, it has to mix a little bit of the colors together with the black to get the desired shiny black print. Dependable in the sense that it also provides cleaning of itself but unfortunately consumes ink in doing so. So you can imagine why the printer would always require the color and or the color ink is consumed even if you are not printing any color images.
There is no solution when the printer senses that there is no longer any ink other than to replace the ink. But, there is a way to fool the printer into thinking that you have replaced the color ink even if in reality the cartridge is empty. To do this, I would have to ask a few questions pls:
  • are you able to download and install several programs that I would provide the link?
  • if ever required, would you able to do a little bit of mechanical work such as working on the cartridge. Mechanical that a hole may have to be enlarged?
  • are you willing to risk destroying one or two of your color empty cartridges?
  • it is also possible that the tricks would make the rpinter inoperable (although slim, but the possibility do exists)?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have run out of one of the color red. Can I
My printer is printing very light........color ink cartridge is new for color but, black is getting low........what should I do.........do I have to replace black before its gone?
Oct 25, 2009 | Konica Minolta magicolor 2300DL Laser...
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Cartridge alignment
So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
78 people viewed this question
old marine
old marine
