Question about Acer Computers & Internet
My Acer TM230 mod. M2132 doesn't keep the screen on. Screen comes on then goes to a shadow type. If you press ctrl - Fn - F6, the screen comes back as it should, but only for about 5 sec.
  • bob_sabo Nov 05, 2008
    no change
    Genius:
  • 1,124 Answers
Check the settings of your screen.
Check Power Settings
Check the power suply and battery
Check the inverter and internal cables
Posted on Nov 05, 2008
  • Pablo Csaky
    Pablo Csaky Nov 05, 2008
    This issue could be related also a video card failure
    Brigadier General:
  • 3,614 Answers
Try first uninstalling and re installing the video card driver and also the monitor driver.
keep us updated. let me know again here
  • micromaster
    micromaster Nov 05, 2008
    auto adjust the setting on the monitor.
    if this one will not solve the problem, try changing the video card and test it with the new one installed.
  • Acer Master
  • 1,879 Answers
Re-install video card driver
    Scholar:
  • 155 Answers
Remove the battery and reinsert after sometime and then check it.
2 Suggested Answers
techniwiz
  • 275 Answers
SOURCE: TM230 M2132 - screen problems. ctrl-Fn-F6 gets it back but only for 5 sec.
go in the safe mode and than uninstall the graphic driver and restart the system and again install the driver again and in case that happenes again chk with a known good monitor and tell me the results
I have the acer aspire 5536-5112 black screen
I solve this using Fn + F6, using a 5536 model. Just press Fn + F6, keep holding it and hit the power button, wait for about 5 or 7 seconds, release the Fn and F6 keys. thank you so much guys!
Oct 19, 2012 | Acer Aspire Computers & Internet
How to switch to vga flat screen on my hp g72-227wm it has a broken lcd screen
Once you connect the Flat screen using a VGA cable or an HDMI cable it should automatically switch the screen to the secondary display. If it doesn't do that then you can press the Fn key which is located at the bottom of the keyboard next to the Ctrl key. Holding the Fn key press the F6 key on the top row of your keyboard. This will help you to switch the display.
Oct 03, 2012 | Computers & Internet
Brighten display screen
Normally, on the keyboard of your netbook, there is a "Fn" key next to the bottom left "Ctrl" key.
after you finish booting up and have the screen veiw, press and hold the "Fn" key, then at the top there are a row of "F' keys, usually the F6 key is the key you would press to increase the brightness of your display. Each time you press the key the brightness should increase, if you press it pass the maximum brightness it will go back to a low brightness and then increase in brightness each time you press the "F6" key.
Remember, you have to hold down the "Fn" key as you press and release the "F6" key.
**** Luck
Aug 27, 2011 | Samsung NC10-14GW Notebook
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
Aug 24, 2011 | Acer Computers & Internet
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Nov 05, 2008 | Computers & Internet
Have a acer aspire 5570 2067 that was dropped and the screen was broken. how do I hook it up to an exterior monitor.
Look at the back of your acer you will be having a blue monitor port or a white,the same should be there at the back of your monitor as well,now one get the cable for the port that your monitor and acer has common.A blue or a white once you connect the monitor and the Acer press this key combination
Fn+F6 .Fn key is the one betwen on the ctrl key and the window key on the keyboard on the left bottom of the keyboard.
May 27, 2008 | Toshiba Satellite A135 Notebook
I think you're trying to output the screen to external monitor right ? So when you press Fn+F6 this will output to external monitor only but if you do it again it will output to both (External and you LCD) and if you repeat the step again you're back to normal.
goodluck,takecare.
May 24, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
