Intel D865GBF Motherboard Logo
Posted on Nov 05, 2008
Mobo will hanged when i configure the the cmos
One day I browse the internet and the screen freeze automatically. What I did is to reset the switch button but no avail. I repeat pressing reset button over and over again yet the pc hangs... The next step that
I did was to configure the CMOS setting by pressing the del button yet i can manage to enter the cmos configuration set up but the pc freeze again,,I wonder whats the problem even if I already isolated the hdd cd rom ide cord still the problems exists,, please do help me tnx..God bless to all
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
3957
Points
11
I think your computer has virus or your temprary memory size is too short to upgrade.
WHERE IS THE CMOS RESET ON A FOXCONN N15235 MOTHERBOARD PLEASE,THANK YOU MUCH
N15235 this is no model that number is for electrical safety certification only.
post the sticker numbers on the mobo tell the true model , all of them, see SP#nnnnnn that is HP mobo
did you buy a used MOBO off the internet,just the MOBO
and no PC??????? not told that
N15235 stamp in on all there mobo every one for decades.
it means zero to you or any tech on earth this CERT
i think it is a Asian code, for sure not here USA ours is UL or RU.
here is your answer
power on and hammer Del key (if not for HP or Dell)
the main BIOS page shows now , new coin cell is a must.
then click bios default settings that resets CMOS NVRAM.
the set time and dead
then set boot order , in BIOS.
no problem stated, just nebular CMOS reset.
2answers
I have an HP G7000 Laptop, but I have forgotten the BIOS Password. Can you pls tell me how to reset it? It has a Hannstar motherboard.
desktops easy
laptops pure H3LL
learn to google this
is is called hacking.
google this way
hack Admin Password, HP G7000 laptop
there will be lots of hits some good , some bad some making it worse.
or ask hp.com to fix it. why come here to hack?
https://search.brave.com/search?q=hack+Admin+Password%2C+HP+G7000+laptop&source=web
Internet not working
Make sure the router is set to DHCP to avoid any IP conflicts. This may be caused by connecting a switch before the router and blocking the routing table.
Why does my internet freeze? what can I do
If your computer as a whole is freezing, then you have to check for viruses / malware.
But, if it is only your internet that freezes up, then try resetting your Internet Explorer.
I am presuming that you are using Internet Explorer 7 or 8, as your browser.
To reset Internet Explorer (IE) :-
1. Open Internet Explorer .
2. Click Tools, and then click Delete Browsing History.
3. In Delete Browsing History, click Delete All.
4. Click to select the Also delete files and settings stored by add-ons
check box, and then click OK.
5. Switch to the Security tab.
6. Click Reset all zones to default level, and then click OK.
7. On the Advanced tab, click Reset.
8. In the Reset Internet Explorer Settings dialog box, click Reset.
9. When Internet Explorer finishes restoring the default settings, click
Close, and then click OK .
10. Uncheck Enable third-party browser extensions option in the Settings box
11. Close Internet Explorer . The changes take effect the next time that
you open Internet Explorer .
Try to reset IE, as explained above.
Even after resetting IE, if IE still freezes, then there may be some viruses / malware on your computer.
2answers
Sir, My computer hang after start
Probably there's a problem with your CMOS battery, try to replace it and update you BIOS.Updating BIOS can be done through the Internet, download the latest firmware to update your BIOS.
Save and reboot your computer.
Hope this Helped!
Internet Explorer freezes when I log onto RTE TV (Ire).
Sir/ Madam -
Please try to use any other browser like firfox or Chrome and see if you are able to stream video. If yes there might be a proble with Internet Explore setting .
Try below steps to fix it --
Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK
Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
Reset Internet Explorer 7 settings loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
Cmos configuration not available by pressing del upon loading
Try to reset the CMOS settings by removing the CMOS battery and leaving it on that state for 5 to 10 minutes then places it back or if your familiar with the CMOS jumpers on the motherboard it is a more effective of resetting it. Give it a try and see if you will be able to access the BIOS setup again.
Hang-ups durring bios screen and hangs at certain times.
hallo, i'm Fernando Kendy from Jakarta, Indonesia
hope i can help with this problem
the mainboard has onboard graphic adapter (S3 bla bla bla)
try using it. unplug your nvidia FX5500
how is it? does it work?
if it still not working, then STOP here. something is wrong with your mainboard
if it is working, then goto BIOS configuration
change the PROCESSOR frequency to 100 MHz (MANUAL) and the RAM frequency to 400MHz
save the configuration, and shut it down immediatelly
plug the nvidia FX5500 back, and turn your pc on...
it should be working fine now
but if you still have problem, then i'm sorry... couldn't help you any further... :)
2answers
Freezes @ Mobo Splash Screen
you have i would say a corrupt bios, if it can't even select the splash screen, i'm assuming that you have tried to reset the cmos by means of the relevant jumpers, either JBAT1, CLRCMOS or CLRCLK or similair. If so and still nothing, when you built the system you may have stressed the board fitting the heatsink and fan or the memory causing the mobo bios chip to fault or it is simply a manufacturer fault and therefore up for exchange of faulty goods.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
