How to restor to factory settings
First of all why would you want to do that? It loses all your data, docs, music, pics, videos and programs since the time you brought it from the store. If you're cleaning it to give to someone else, why not create another user account with their name with administrative rights, then restart and log on using the name you assigned for them. Then go back into the user accounts, click on your user account that has everything you've done as far as docs, music, pics, videos, etc. and click on Delete Account. When prompted about the files associated with the account select the option to delete them also.
But if you must get back to factory settings you will need to either have a disc that has the original image on it, or somewhere on your hard drive there will be another partition (Recovery Partition) that you can use to restore. Normally when you boot your machine you can hit a F1 thru F12 Function key that will get you into the recovery process. On some computers you can get into the recovery process from windows by clicking Start/Programs and look for anything that references recovery.
SOURCE: factory setting restore
Does the laptop have a restore function built in?
When you start it up do you see anything that indicates a restore program?
SOURCE: acer 3680 factory reset
here is the link to the manual for your laptop. please go there and take note of pages 70-73 that show how to restore your system with and without the disks.
SOURCE: restoring averatec 3150 laptop to factory setings
With no disk you cannot restore your computer to a factory settings, at least that your computer has a second disk with the restore settings installed on it (usually this disk is called restored)
SOURCE: I want to reset my IBM thinkPad R50e back to factory Settings.
CREATE A BACK OF DATA INIT
BETTER THEN RESTORING U CAN RESTORE UR SYSTEM TO A PERIOD WHEN UR THINKPAD WAS RUNNING SUCCESSFULLY AND THIS DOESNT DELETE ANY DATA ON UR HARD DISK
START PROGRAMMES ACCESSORIES
SYSTEM TOOLS SYSTEM RESTORE
THIS WILL SURELY HELP U
SOURCE: how do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
Click "Start" menu.
Click "Programs."
