Question about Whirlpool Washing Machines
I have a Whirlpool AWM-5130 (AA 1200) The spin dryer on the washing machine does not appear to be functioning any more. It sounds like the drum is being agitated. It is 4 years old and used on a daily basis
Sostituire i cuscinetti
Posted on Mar 10, 2011
Scheme to replace the bearings whirlpool AWM 5130
Are you ready for a big job?
It means taking the machine right down - drum out and spider off.
If you think you have the skilss and can get the parts locally - check that you can get the bearing - you might need a complete assembly.
If you can get all the bits and still feel up to it - get back to us.
GOOD LUCK
Mar 10, 2011 | Whirlpool AWM5125/1 Front Load Washer
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
My washer whirlpool awm 258-1200 nordic makes bumping sounds
your machine and indeed every washing machine has a large cement brick on top of the drum inside if this gets loose or breaks it knocks the machine of balance causing the machine to make a bumping sound mostly when starting.adrian,,,,
Jun 28, 2010 | Washing Machines
Hi, my AWM 1200 is 9yrs old but still washes and
Your machine most probably has had water in the spin bearing. The seal has worn and allowed water to rust the ball bearings which are no longer smooth...Hence the noise! A fairly major job which could also need a new shaft and inner drum. Get quotes, but be prepaired. Too much detergent can also speed up seal failure......Good luck....Nomess
May 13, 2010 | Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
How to remove Bra wire trapped between drums.
Try to see if there is a large rubber sleeve underneath that you can remove. It will probably be fastened with a clamp. Make very sure that you get it tightened afterwards, or it may leak.
Dec 05, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
671 people viewed this question
Dan Webster
Dan Webster
Sal De
