My new Toshiba DVD/VCR Combo has no built-in tuner
I just bought a new DVD/VCR combo to replace our old one that was dying. When we went to hook it up, we noticed there was no place to hook up our cable tv. The instructions talked about hooking it up to a TV tuner box. I e-mailed Toshiba tech support and they said that most DVD/VCRs manufactured in 2007 and later don't have built-in tuners and suggested I return it and trade up to a model that does have the tuner built-in or contact our cable company for a cable box. I had never heard of this, so it didn't occur to me to look for that particular feature, as we have always been able to hook up any VCR/DVD recorder we have owned to our cable. Unfortunately, the online company I bought it from has a no returns policy on that particular item - they will swap a damaged unit for one of the same model and that's it. I then contacted our cable company and they said in order to get the box we would have to upgrade our current service for an extra $10/month. Not wanting to spend the extra money on an ongoing basis, I went looking for one I could purchase outright for a one-time expense. I've check Wal-Mart, Radio Shack and googled every online store for a tuner box or a workaround/adapter with no luck.
Despite all the cool features this unit offers, the primary reason for buying it was to be able to tape our shows from our cable service when we aren't able to see them "live". Does anyone know if there is anything I can do short of buying another unit or upgrading our cable to gain this feature back that we have always had?
  • kbarcenilla Nov 27, 2008
    Same problem - no tuner. I am wondering if the converter box that is advertised to help people who will need it when the conversion from analog to digital takes place in 2/09 would solve this problem.
    Problem Solver:
  • 4 Answers
I'm not sure if you can do this using the timer recording, BUT....if you use the AV plugs (the ones with the red, white and yellow plugs) to connect the VCR to the TV, you can tape what is actually on the TV at that time.....you are using the TV tuner and just taping that on the VCR. As I said, I'm not sure if this works with timer recordings.....maybe if you leave the TV set on the proper channel? Try it and see if it works.
Posted on Jan 03, 2009
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
Can't find a coaxial connection on sungale dvd-2026 player
The only DVD players that have coaxial inputs and outputs are Combo Sets with a tuner built in.
If, for instance your DVD player were a combo VCR/DVD player, your VCR would have a tuner built in with it.
Sep 14, 2010 | Sungale DVD-2026 DVD Player
Do they make a DVD/VHS Combo with a built in decoder that will connect to my Analog TV using only a coaxil cable?
99.99% of the combo units that have a tuner inside have been phased out.
You do need an external tuner to get cable through to the combo unit. The only combo units that I have seen that has a tuner in it already and hooks up to the coax is one that is a vhs/dvd RECORDER and not just a vhs/dvd PLAYER. You pay extra for the built in tuner and also for the dvd recording features.
Dec 27, 2009 | Televison & Video
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Samsung DVD V9700
Double check the cables. if it has a tuner, use that
Nov 25, 2007 | Samsung DVD-V4600 DVD Player/VCR
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Televison & Video
Televison & Video Logo
376 people viewed this question
Top Televison & Video Experts
