Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis washer
I purchased the oasis and had it about a month and the "f" code kept coming on. I had sears replace it for me and now a week after having the new one the same thing is happening. It will not go passed the wash cycle. We are in a brand new built house. Could it be our electrical wiring? Any ideas??? Thanks
  • 1 more comment
  • jenine havens Oct 13, 2006
    The Sears tech was here today and said the problem was the motor sensor. A part would have to be ordered. I refuse to wait 5-10 days for a part for a week old washer. Any advise on any other machine that will wash a king size comforter?????
    Thanks
    Jenine
  • Anonymous Jun 15, 2008
    I had the same problem with my new Kenmore Oasis washer, it stopped part way through the wash and then I got the F code. Technician replaced the motor sensor (this was one month ago) and today the same thing happened again. I hate this washer. Wish I had of bought the old dasher kind as they were dependable. Oh well. Technician has been called again to fix it. Should be here in a couple of days. Wonder how long it will work this time.
  • Anonymous Apr 27, 2009
    water leaking from bottom when rinsing
    President:
  • 878 Answers
Jenine, I have run into this problem on a few of the Oasis washers. In talking to the Whirlpool tech rep (Whirlpool makes the Oasis), I was under the understanding that they had some issues with the initial main board supplied in these washers causing the F code. Therefore, in changing this washer out, you probably received one in stock with the same board. What I would do, since it's under warranty is to have the technician order a board from the factory. Any revisions to the new board should be in there. As long as you have both water valves on, no clogged screens on the hoses and 120 volts at the outlet your washer should operate normally. Catriver...post back.
Posted on Oct 08, 2006
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
Aug 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer fills and starts for a while and then stops
I recieved the followng letter from sears last week since we had registered our OASIS He washer two years ago since we purchased it new. The washer has a serial number that is authorized to get a replacement board, and the part has been shipped to my house. Once it arrives, we are to call the local Sears dept for someone to install the new board.
For washers that have the first four of the serial numbers as:
CS48-CS52 or CT01-CT49 qualify for the replacement Control Board.
1-800-847-9083 between 8am-8pm M-Saturday.
Good Luck all.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Control Unit Assembly
We are researching for new laundry machines (10) for our condominium laundry room. I'm glad I found this site, and I guess we won't be buying Kenmore products.
Saratoga Condominiums
Oct 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Recall on kenmore oasis
I have one of the first kenmore oasis and I get the F1 and off balance error all the time I called the recall number line is 1 (800) 659 7026 they said that they are doing a free upgrade to replace the control board the only problem is the board is on a back order and it may take a week to get the part in.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
OASIS HE 27092 - Strange power problem
Just had the same issue a couple weeks back. I ordered the control board and replaced myself. Machine comes back to life like a magic.
May 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Digital display f--, only had for month
You are absolutely right. Since it still under warranty, you should contact Sears for it.
Oct 13, 2006 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
187 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
