Question about GE JBP25 Electric Kitchen Range
Oven not heating and oven control lights not working
When I turn my oven on the oven light on the panel does not come on a nd the oven it's self does not heat up. All of the stove burners work fine and the lights for them come on fine. Please help :(
  • cactusjk Nov 08, 2008
    Thanks for your help. It ended up being the control board and probe. Cheaper to buy a new range than fix the old one. :) Have a great day
  • 417 Answers
Check if the oven is in AUTO cook mode. It should be in MANUAL cook mode , check if it has a MANUAL mode button. Sometimes resetting the clock will put it back into MANUAL mode.
Posted on Nov 05, 2008
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After using self clean oven will not heat on any setting
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 17, 2009 | Whirlpool RBS275PD Electric Single Oven
Turned on self clean on my GE Spectra JBP24B0B4WH Range
Hello Cliff Hendershot,
One USA manual ... said turn off power for 10 minutes
(sounds reasonable after looking up cost of control board)...
USA websites are not responding to your number.
Closest I could get was to a $78 (us dollar) control panel
>> ((IMPORTANT PART ... has a video that shows repair))
http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
I could NOT get a good READ on your JBP24... page 8
So I attached a JBP19 (below)... Page 12.
The most COMMON reason to FAIL after a cleaning cycle
is your OVEN CONTROL is "off normal"
(You still do not have your MANUAL MODE restored).
Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
Check your "oven controls"
else
Oven elements do break during routine use...
Check both roast & bake elements for continuity.
GE JBP19 Owner Manual Usingthe Oven
Carnac the Magnificent
Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Self Cleaning light comes on and flashes when you turn on oven!
It sounds like you have a defective Oven control module. (TO8 Control) is the part that controls all oven functions including clean,clock,timed bake, ect. Item is easy to replace yourself.
Mar 29, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
GE JBP25 Electric Kitchen Range Logo
327 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
