Question about Whirlpool LER4634J Electric Dryer
Condenser dryer not getting clothes dry
My Whirlpool condenser dryer AWZ 650 is not generating any and will not the clothes I put in, I have checked the filters and they are clean. Do you have any idea what could be the problem and can I buy spares for this machine.
Kind Regards.
John Williams.
  • Whirlpool Master
  • 19,396 Answers
There must be one or two circuit breakers, usually at the back of the dryer, check them out.
If this does not fix the problem, then possible faults are the thermistor or the heating element.
Most likely you will need to have the heating element replaced.
If you decide to call a technician you can use the phone number listed on the owner manual.
You can find parts and diagrams here.
See also this website, the also sell parts and have some schematic: What is wrong with your Dryer?
Posted on Nov 05, 2008
Why my Whrilpool Drier AWZ 555 is not drying the clothes and power light is blinking?
Check to make sure it's getting full 240vac power. Some or most driers are fed from two breakers in the box. If one is tripped you aren't getting enough power. That could be causing the blinking light. Also check for enough exhaust flow to prevent overheating.
May 18, 2014 | Whirlpool Dryers
Awz 412 washing machine/dryer.
With a washer and drier thay do , a separate drier would be better for you
Dec 13, 2017 | Whirlpool Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
MY WHIRLPOOL AWZ 3303 IS WORKING BUT NOT GETTING HOT OR DRY CLOTHES
obviously a fault with the heater circuit first check your thermostat and then your heater element and replace as needed
Aug 11, 2010 | Whirlpool Dryers
Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Mar 20, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
DRYER IS NOT HEATING TO DRY CLOTHES MODEL AWZ 650
could be the heating element,hi-limit switch,cycling switch door switch,missing input power or part of the input power,burned neutral on the element if used
Oct 27, 2009 | Dryers
Awz 8477 when turned on is not getting hot and drying clothes , it is still circulating air
check for a broken coil in the heating element. if it is ok, then check the thermostat(s) mounted on the heater housing.
Oct 24, 2009 | Whirlpool Dryers
Whirlpool AWZ 650 condenser dryer is not heating - cold air only
MY FILTER LIGHT IS ONN ALL THE TIME, HOW DO I CLEAN THE FILTER...WHERE IS IT, IS IT THE ONE BELOW THE FRONT DOOR THAT PULLS UP AS IN THAT CASE I'VE CLEANED THAT?
Jul 06, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
458 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
