Question about Microwave Ovens
Door does not latch when closing on Sharp Carousel model R1480 Ser.# 221885 Microwave oven
  • Anonymous Feb 28, 2009
    mine turns on when you shut the door even though the microwave is not cooking
  • wadesaylor Feb 28, 2009
    does not latch
  • Microwave Ovens Master
  • 9,086 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the internal spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here but the best place to order Sharp parts is Tritronics.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 08, 2008
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
The microwave will not come on ,however the timer starts running . If you hold the latch in slightly it will run correctly but you have to keep it pressed in. I have the sharp carousel model 1200watt
Your door is misaligned dont use it by holding it Ionce you tighten the door correctly then adjust the door switch where the door latches and make click sound Thanks Please rate me
Aug 27, 2011 | Sharp R-510HW Microwave Oven
My door latch pushes in but does not open the door.
But does not what? If the door doesn't open, chances are the seal has gotten sticky so try to apply a little outward pull... If it is sticky and opens, wipe down with moist cloth both the seal and the mating surface.
May 29, 2010 | Sharp R-230 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Sharp R1480 - door won't close
Very much so.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
Dec 14, 2008 | Sharp R-1480 Microwave Oven
Sharp R1480 door won't close
Very much so.
You will need the
Microwave Ovens Logo
254 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
