Question about Dryers
Dryer not getting clothes dry
My clothes dryer is not generating any heat to dry the clothes, I have checked all the filters and they are clean, do you have any ideas.
Regards
John Williams
  • 135 Answers
This will most likely be a problem with the heating element or a thermal cutout which are usually located on or around the element.some makes have cutouts with a reset button whitch when pressed will restore heat.
Posted on Nov 05, 2008
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
I have a Whirlpool duet washer and dryer. The dryer is not working well. the ligts come on and it spins but it doesn't dry the clothes, what can the problem be?
Is it heating or not? Is this gas or electric? The first thing to check is your vent and clean the lint filter. Then you should check the heating element and the thermal fuses if it is not heating (assuming electric). If it is heating and you're not getting dry clothes then your venting must have issues. Good luck.
May 02, 2011 | Whirlpool Dryers
I have model 110.60832990 and the dryer is on the drum is turning, the heat is on but the clothes are not drying.
Check the air outlet and see it is not clogged with dirt/flint. Clean the air filter mesh located at the air outlet of flint. This blocks the free flow of air and thus do not dry the clothes. Drying will take place when the air inside has free flow. Before putting clothes in the dryer EVERYTIME this filter must be cleaned OR after every drying cycle.
Aug 29, 2010 | Dryers
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
No heat when drying
You need to check the heater element and thermostats which are lolcated behhind a removeable panel at the rear of the dryer..
You will need a meter to do this. Remove one wire from each thermostat and with the meter on the ohms range, test for continuity,if the stats are o/k you will get full scale deflection on the meter., if no movement then stat faulty, you must replace both stats at the same time.
take note which stat goes where as it is important you get them the right way round.
If stats o/k then the heater element is probably faulty.Plz rate my solution.
Thanks.
PS, make sure all filters and vents are clean
Particularly the filter at the bottom left, remove it and wash it out under running water.
Jan 02, 2009 | Dryers
Condenser dryer not getting clothes dry
There must be one or two circuit breakers, usually at the back of the dryer, check them out.
If this does not fix the problem, then possible faults are the thermistor or the heating element.
Most likely you will need to have the heating element replaced.
If you decide to call a technician you can use the phone number listed on the owner manual.
You can find parts and diagrams here.
See also this website, the also sell parts and have some schematic: What is wrong with your Dryer?
Nov 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
197 people viewed this question
Top Dryers Experts
