Question about Philips 46PP9302 46" Rear Projection Television
Waves Hi i have a philips 46" tv model #46pp930127 in which there is a wave down on the bottom of the screen. (like 3-D )We were wondering what could have caused this and how to fix it. Thanks Karrie
    President:
  • 3,130 Answers
If they are green, red and blue lines, you have a typical convergence problem that happens in almost every rear tube projection set ever made. There are two IC's that need replacing to correct your problem. If you do not know how to solder, unsolder, work on solid state electronics, you really should call out an experienced tech to assist you in this repair. These sets now a days have no user replaceable parts inside of them. A TV set as this one, should not be a place to experiment around inside of. Good Luck
Posted on Oct 09, 2006
I have a Panasonic Quintrix F TV. About 6 weeks ago the tv screen started displaying
Rule out the signal source by seeing if same issue when a DVD etc is used.
Usually a wave like motion from bottom to top is either signal related or a problem in the power supply (wave moves from bottom to top suggests that).
If not on rear inputs (A/V) it is not the power supply.
Model number is not indicated here and might be helpful.
SD TECH
May 26, 2012 | Televison & Video
My screen has waves in the top and bottom and the colors is off with the waves what is the problem?
Convergence ICs have failed. Relace the two Ics and check the 6.8 ohm resistors. You can get the Phillips DPTV305 - DPTV345 convergence repair kit which also works for your model from www.tvrepairworld.com the kit contains the ICs and all the resistors plus a cd with detailed instructions.
Jan 02, 2010 | Philips 60P8342 60" Rear Projection...
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The top rite and leaft of my screen coners are out
Wave would indicate your loosing high voltage and the tv is nearing the end. You can tweak hv, but its a short lived solution. Good luck
Jul 09, 2009 | Philips 60PP9202 60" Rear Projection...
Waves on new Polaroid LCD 42 inch screen
try a different signal source, if its still a prob return it.
Dec 02, 2008 | Televison & Video
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Convergence Projection tv
Explain the wave. Do you mean your video is shrinking then expanding. If so www.magnavoxhelp.com has a kit that will fix this common problem.
Jul 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
John
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 46PP9302 46" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
