Question about Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 Automatic Feed Malfunction
I am having a problem with the automatic feed tray on my brother printer. The machine will do 1 print job and then automatically revert to manual feed. The machine will no longer print unless you manually feed paper into it. I have tried to reinstall the drivers and have also looked at my settings and see no reason as to why the machine would do so. Anyone had a similar problem?.
    Champion:
  • 320 Answers
You need to reset it from the printer setup menu
Posted on Jan 14, 2009
Suddenly, our Brother MFC 9840cdw keeps spinning its top paper feed rollers, forevier, and says Fax Only, Please Wait. When we press the Copy or Print buttons to get out of Fax mode, nothing happens. I...
It does sound like a paper sensor in the automatic document feeder may be stuck and the machine keeps trying to eject the paper that is not there. I have not seen this before, you may have to call Brother at 1-877-BROTHER to find the nearest service center.
Jun 02, 2011 | Brother MFC-9840CDW Laser Printer
Manual feed paper
that's easy thing, you should right click on printer icon and in property, check that option, you will find that optop paper feed, change it from manualy to automatic.
May 27, 2010 | Brother MFC-7420 Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
BROTHER MFC 8440 ERROR "NO PAPER"
Check the paper tray adjustable guides inside the tray; the guides need to fit around the paper snug, when re-inserting the tray if the rear guide is back too far the paper may be shifted towards the front of the tray out of range of the paper sensor so it thinks it's out of paper. I service HP LaserJet printers and most of the time this is the problem. Hope this helps.
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
How to print envelopes
Open the manual feed tray door (that is the door on the front that has the "Brother" logo on it. Narrow the feed tray guides to filt your envelope. Envelopes feed it with flap side up and to the left.
Dec 30, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
MFC 8440
the automatic paper feed is not working
Jan 31, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
257 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
