BEKO WASHING MACHINE, HEARD A FUNNY NOISE WHEN IT WAS SPINNING, THERE WERE SPARKS COMING FOM UNDERNEATH THE MACHINE, TURNED IT OFF?
    President:
  • 1,462 Answers
Almost certainly trhe motor burnt out and are expensive unless you can get one secondhand
Posted on Nov 05, 2008
Small water leak from under the washing machine
not un common for manufacturers to test every 5th , 3rd , 10 th machine if yours came with a defective/ cut/ or otherwise failed pump to drain hose or tub to pump hose. my 15 years in the business hint noisy in spin points at unseated main tub seal/bearing call for factory service don't void warranty by fiddling with it your self ( maybe an easy fix slipped hose,maybe a 3 hr repair for a qualified journeyman appliance technician.
Oct 24, 2016 | Beko Washing Machines
Leaking gas underneath engine on drivers side
it may be that u are leaking gas from the fuel line. follow it from tank to the engine and look for a leak. do this asap as it is fire hazard
Apr 07, 2014 | 1995 Toyota Corolla
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
Replaced beko motor brushes on washing machine and they are making funny noise
Please remove and reset the brushes are it could be out of alignment , Please check this link for tips: Brush setting
Feb 01, 2013 | Washing Machines
SPARKS ARE COMING FROM UNDERNEATH MY HOTPOINT WASHING MACHINE WHEN DRUM IS IN ACTION
hi dont worry the carbon brushes in the motor need replacing soon it will stop spinning if you remove them you will notice that the carbon brush is very short should be an inch long they are easy to change thankyou good luck
Jan 18, 2011 | Hotpoint Washing Machines
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
