Question about HP OfficeJet 6210 All-In-One InkJet Printer
How to hook up 6210 printer to compac presario computer?
My printer doesn't have a standard printer cable port that hooks to my computer. What type printer cable do I need and how do I hook it up?
  • Anonymous Feb 01, 2009
    I am not sure if I have all of the necessary cords to hook up my computer. What do I need? I bought this printer from a pawn shop.
    Novelist:
  • 173 Answers
Your printer has a USB aside from the PicbridgeHP PCL3 connection so you should be able to install it in any computer with a working USB port.
Posted on Nov 05, 2008
What kind of usb plug i need for lexmark8350 to hook my pc
The USB cable would be the standard A/B cable. the port on the back of the printer, is located under the phone line jack. Open the attached URL for the setup guide.
http://www.lexmark.com/publications/pdfs/8300/eng/setupsh.pdf
Mar 16, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Can I hook up a HDMI cable to my Compaq Presario CQ70-120 US Notebook PC?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01550112&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3795242
So no, it doesn't have a port for it. Only a VGA cable.
Sep 16, 2011 | HP Compaq Presario CQ70-120US Laptop
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Now how do you hook up the printer
Hello there:
First what you will have to do is to install the cd rom and install the drivers and then it will tell you when to hook up the cable to the printer and it will show you the location where it needs to hook up then simply hook up a printer cable that should have came with the printer or if you do not have it you can get from any computer store or even walmart and it just simply connects to the computer on the back or if it is a usb type you can hook it up to any usb there as well and on the other end hooks to the printer port ok then it will recognize the printer and finish installing the hardware for you then you will have to restart the computer and you will be done ok?
I hope this is very helpful for you
Best regards Michael
Dec 16, 2009 | HP LaserJet 1022 Printer
Datacard ID Card printer has scsi port and I have no idea...
It is not a scsi port it is a parallel port, the end that plugs into the printer just uses a smaller parallel connector, the other end will plug into a standard printer port. The cable is common used bu HP and Datacard, We have some used for about $10 Plus shipping www.midwestidsolutions.com
MidWestIdSolutions (DOT) com contact us for ordering
Apr 10, 2009 | Platinum Datacard Magna ID Card Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Don't know how to setup printer or hook to computer
Hello calbj5, Since you didn't provide a make /model computer or printer..all I can provide is general guidelines for you.. Your printer will have a few features in that you will need to determine what fits your system best.. Many newer printers use a USB port to communicate with the computer.. This is a modular type plug ( one end will match the plug on your printer ) and the other end will be plugge dinto any available USB port on the back of your computer, ( older systems used what they call a D-Type cable assembly ) and if tha is what you require, you willl need to get that cable. Like I said.. most newer style printers come with the USB type cable as standard. You will also find the power cord provided with your printer..One ened plugs into the back or side mating plug of the printer and the other to your power receptacle ( hopefully you are using a surge protector set up)
Once you have both cables hooked up and plugged in.. you've probably been provided with a CD that came with your computer as well as instructions for loading the drivers on that CD ( most of the time) you just insert the CD into your CD player and it wil ask a few questions and self load.. Please let me know if this gets you going or youneed clarification.. It's always a good idea to provide brand and model numbers in your questions.. That helps us in helping you.. Good Luck !
Sep 23, 2008 | Computers & Internet
Needto hook printer to computer
does your compaq presario have a parallel port? kx-p1124 usually comes with parallel ports
Apr 18, 2008 | Computers & Internet
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
