Cmos configuration not available by pressing del upon loading
My gigabyte mobo no longer operates normally. What I did is to configure first its cmos setting by pressing del upon loading but i can no longer be displayed.. Please do help me how to fix the problem..In other words no matter what i do it is no longer usable because i can no longer configure the cmos setting for its failure to display. the pc hangs after detecting the cd rom and hdd then stops,,, if i press del the cmos will not be displayed
    Novelist:
  • 171 Answers
Try to reset the CMOS settings by removing the CMOS battery and leaving it on that state for 5 to 10 minutes then places it back or if your familiar with the CMOS jumpers on the motherboard it is a more effective of resetting it. Give it a try and see if you will be able to access the BIOS setup again.
Posted on Nov 05, 2008
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
I tried changing keyboards,nothing. when I pluged it back in totaly dead, had to plull off jumper, now its running ( fans) that is and performing automatic IDE configuration. [Invalid configuration info...
Many motherboards have a "clear CMOS jumper" capability. There are 3 pins on the Mobo and the jumper is put on pins 1 - 2 for normal operation and moved to position 2 - 3 to clear CMOS memory. (It may be the other way around on some Mobo's). Your PC will oly work with the jumper in the normal position. If you temoraily moved it to the clear position (and then put it back to normal) you erased your cmos memory which remembers the date & time, hard drive cofiguration and many other importnt parameters which need to be set correctly in order for your PC to run properly. If you have the manual that came with your motherboard, it explains how to go into cmos setup and set these parameters. If you do not have this manul, navigate through the menus and choose "default (or optimal) bios settings" Then set your date and time, choose save bios settings and exit bios setup. Hopefuly your computer will start up OK now. If not, you should find a PC technician to help you.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 25, 2011 | Computers & Internet
I have gigabyte gl 81915 motherboard on my cabinet. but some days ago it's display check sum error default loaded so how can i solve it give me solution?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time
Sep 02, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Mobo will hanged when i configure the the cmos
I think your computer has virus or your temprary memory size is too short to upgrade.
Nov 05, 2008 | Intel D865GBF Motherboard
Cmos settings
configure first the cmos setting by means of pressing f8 while booting. then press the load optimal setting and save it.
Apr 28, 2008 | EliteGroup P4VMM2 Motherboard
ASUS A*S-X not recognizing cpu
you should be able to press F2 or Del on boot up to get into the bios, but you should replace the battery first then set everything up as the cmos has obviously lost it's saved settings because the battery is flat.
Sep 10, 2007 | ASUS A8S-X Motherboard
CMOS battery drains after one startup. Gigabyte GA-K8N-SLI
OK lets see here! Make sure your CMOS jumper is set properly on the board(Set to Normal) or Did you configure your bios after flashing the bios(going into bios and Load Optimized Defaults!)? or I don't think it would be another device in the system, but you can try troubleshooting by starting up with only what you need to run the machine (Mobo, memory harddrive, keyboard and mouse) then one by one adding devices back! or Did you have problems like this b4 you flashed the bios! Try flashing the bios back to an older version! post back if anything new or if i'm way off! Good Luck regards, babb
May 03, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Computers & Internet Logo
771 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
