Question about Toshiba 65H82 65" Rear Projection Television
Toshiba 65h82 picture trouble
The picture began being blurry a few months ago and now it is completely blurred for the first 20 to 25 minutes. After that it halfway clears up, but it never clears up all of the way. And it does this every time it is powered on reguardless of how long it has been off. I have called atleast 20 different repairmen and none of them know what the problem could be but for $800 they would come pick it up and take it to their shop to work on and be happy to charge me for their time while trouble shooting. And even then there is no gaurantee that they will be able to fix it. Please help, I don't have a problem with paying whatever it costs as long as it will resolve the problem. Thank you for your time, Duffy Brown
    President:
  • 3,130 Answers
Its most likly the Hi voltage/focus block assy. Or there are bad capacitors in the sweep power supply. You should call toshiba and get the number of an authorized Toshiba repair shop.
Posted on Oct 08, 2006
My toshiba 65 rear projection is blurry and has dual image
The fluid that is used to cool the face of the 3 tubes has become clouded and discolored. This fluid is serviceable. I wouldn't try it myself if you've never done it before. A TV shop can do the job.
Oct 09, 2014 | Toshiba 65H82 65" Rear Projection...
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Aug 30, 2017 | Nikon Coolpix S4300 16.0-Megapixel Digital...
I have a Toshiba 65H82 and at first the picture was blurry but would clear up after about 10 mins now the picture just stays blurry. Can you tell me what the problem could be and if it is worth fixing it?...
Try adjusting the focus block this requires opening the back and front bezel of the TV. If it doesn't clear up after adjustment attempts then the liquid coolant inside each of the tubes need to be emptied and refilled with new coolant. Over time the coolant gets cloudy and can cause a blurry image with a white sheen. Contact me at the link below so I can help you further.....if this helps please rate:-)
Thank you:-)
http://tvtechwork.webs.com/
Oct 21, 2010 | Toshiba 65H82 65" Rear Projection...
All of a sudden everything is out of focus and very blurry, pictures and even through the view finder. we took a few pics tht turned out normal, set the camera down picked it up about 5-10 minutes later...
If the viewfinder is also blurry, it might be as simple as a smudge on the lens. Is the blur uniform and consistent on the pictures and in the viewfinder? Was there a curious dog nearby when you set the camera down?:)
Sep 20, 2009 | Sony Cameras
I have audio but no video...
Deflection Board resolder all Pinns on (FBT) Flyback Transfomer.
Nov 02, 2008 | RCA D52W23 52" HDTV CRT TV
Picture is blurry on new Toshiba 42HL67 lcd tv
Hi suegy, the quickest thing to test is play a dvd and observe the quality of the display. if still blurry or dull, could mean something wrong with your TV. going through what causing it...could be weak signal or CCFL lamp not glowing enough or fully.
Since its only a month ago, should be still u/warranty. Check out where you bought from and avail that warranty.
Good Luck.
Feb 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Blurred Pictures
1. What is the focal length of lens you are using? 2. Is the blur occurring with lens with a lower focal length than the telelens? 3. Do you still get a blur when you use the telelens with a tripod or a firm base? Regards Raman
Oct 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
