Question about Sony DVP-NS575P DVD Player
No colour picture - Sony DVP-NS575P DVD Player
  • Sony Master
  • 6,771 Answers
Sub the audio/video cable from the player to the TV, causes issues. If no! check player with another TV set, just to rule out, If DVD player is the problem, it is the laser pickup, or the video processor ic. Far cheaper to replace the device.
Posted on Mar 19, 2012
SOURCE:
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
My Nikon D50 in picture play back mode is giving pictures in multi colour not as pictures ?
I'm not sure what you mean by "multi-colour mode" but this page shows all of the possible playback display modes and describes them. Hopefully this helps you. I use a D7000 which is quite similar and I've never seen a multi-color mode. Nikon D50 SLR Review
Mar 23, 2014 | Nikon Cameras
How to make colour best in ps2 game
your tv will have more control of colour/picture quality. but depending on what cable you are using. if you are only using the S-video cable you will get better picture using the Component Video (Y, Cb/Pb, Cr/Pr) cable. change the video output setting from RGB to composite mode and that should improve the picture quailty
Mar 20, 2014 | Sony PlayStation Video Game Consoles &...
I replaced lamp on my toshiba 50hm66 tv and now i got a black and white picture
Hello
As it is a DLP projection TV, there will be a colour wheel to filter colur. If the whell does not spins at all, or spins out of synchronisation, there will be no colour to the picture. Just check the clour wheel. If needy, replace it. Clean it with cleaning solution. If you don't have eneough knoledge in alaigning the colour wheel, just get help fro an expecienced service technician. There is an RPM [Rotation Per Minute] counter to count the number of rotation of the colour wheel. If this sensor has some fault with, the colour wheel won't syncronise to its original speed what it should be, resulting out of colour picture. OK.
Sep 14, 2011 | Toshiba 50HM66 52" Television
I need the picture settings for a trutech tv. For example : number for contrast .
Hello
The picture setting for any TV depends upon the taste of the viewer. Contrast is the deepness of details in black and grey level. In most TVs a 55 to 75% of contrast will give a good picture. you have to adjust the brightness level also according to contrast. It is best ot turn out colour to 0% first. Adjust contrast and brightness to get a well detailed B/W picture first. The apply enough colour to that B/W picture according to your taste. Face colour of a newsreader at studio will be the best reference to intensity of colour.OK.
Jul 06, 2011 | Televison & Video
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Picture has multicolours and is like a colour
Picture has moving multicolours and is like a colour ngative on the samsung digital tv. Model la37a450c1
Aug 14, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Sony DVP-NS575P DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
