Question about Minolta DiALTA Di181 Printer
Dirty copy First page of each print job is very dirty, following pages are clean. How do I correct the problem? Thanks.
  • dave0074 Nov 17, 2008
    Our copier/printer tech has attemted several times to determine the problem and has taken out the drum and cleaned, still hasn't dermined the problem. Next step is to start replacing parts.$$$$$$$ Need advice from Minolta senior tech.
  • dave0074 Nov 22, 2008
    Are there any Minolta copier techs out there?
    Genius:
  • 1,011 Answers
Dear,
clean it properly but before cleaning it internally check it by changing the grammage of paper.
check it with high gram paper and then use the lower grammage..
regards,
Posted on Nov 22, 2008
  • SALMAN NASEER Nov 22, 2008
    dear,
    are u facing the line too in print like hairlines..
    regards,
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
clean the drum with tissue
or replaced the drum if it is on its capacity of copies!!!
  • 849 Answers
THIS PROBLEM OFTEN COMES WHEN THE DRUM GOES OLD ENOUGH, U NEED TO CHANGE THE DRUM.
  • 4,806 Answers
What ginko says is absoloutly right, there is nothing much else that you can do apart from using the printers own software to clean the internals
regards
Posted on Nov 17, 2008
  • Minolta Master
  • 19,396 Answers
The printer must be cleaned internally.
See and follow the detailed instructions on the following website to clean the printer:
Clean your laser printer safely with these tips
  • Ginko
    Ginko Nov 17, 2008
    If the problem persists after cleaning the printer with the procedure above, then it is probably a faulty toner cartridge or a drum in need of replacement.
    Usually you get rid of this kind of problems by cleaning the printer.
Printer producing dirty copies
it could be that the roller needs cleaning, how you do that, I don't know, but that's my guess. try printing blank white pages and see if they come out dirty
Nov 26, 2013 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Copier is making very dirty prints and copies have had service man in can't seem to correct problem
That will be the drum cleaning brush. It's job is to remove left-over toner, and clean the surface for the next page. Also, check the toner waste bottle - it may be full.
Oct 16, 2009 | Lanier UNKNOWN
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Black marks on the entire page
If the marks look like brushstokes all over the page, then it most likely needs a drum GPR-6. Black marks can be caused by a dirty **** glass (the thin one) as well. the easyest way to tell is if the black lines are only on copies that went through the feeder and not on print jobs, faxes,or copies made off the glass then the **** glass needs cleaned.
Jul 29, 2009 | Canon imageRUNNER 2200
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
May 06, 2009 | Lexmark X7350 All-In-One Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
69 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
