Question about Hitachi 55HDS69 55 in. Plasma Television
55HDS69 Power Supply problem
Hi. the power supply in the Plasma has quit putting out the 96 volt supply. The vendor wants $400.00 for the supply board. Anyone know a better place to get one? Any idea if it is fixable? Or at least, where I might get a schematic for the board?
Any help is appreciated!!
Thanks
Rob
  • Anonymous Mar 10, 2009
    Thanks for the info, I may try to just hack it by putting a 5v logic true on those inputs, but I'd rather find the real issue!  I replace the Digital Main board to no avail.  At nearly $200 per board, I am hesitant to continue this game of chance!
    Thanks
    Rob
I have found that the power supply is usually good, it's the other boards that tell it to shut down within a second. There are input called Vsego and VSago that tell the power supply to stay on.
Posted on Mar 09, 2009
  • imflash3 Mar 12, 2009
    What is the part # of the board you put in? I am trying to find a logical solution for all these 55" Hitachi plasma that have this same problem. Thanks, John.
  • 29 Answers
Hi.
I have a new power supply.
Do you wanted??
Write me at servicio_hitachi@hotmail.com
Posted on Dec 30, 2008
Hitachi 55" plasma: No picture, no sound
Perhaps the seller forgot to mention the basic power supply problems and who knows what else
Jun 12, 2013 | Hitachi 55HDS69 55 in. Plasma Television
55hds69 plasma tv
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply.
I hope this helps
Oct 11, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi plasma p55t551 screen went blank but still power on n good sound
Any number of issues including power supply to main board are possible------Have you removed power from the set and or a box if used for a while?
Nov 05, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55hds69 has sound but no picture
someone has to open and start by testing voltages into and out of the power supply board to rule it in or out.
May 14, 2012 | Hitachi 55HDS69 55 in. Plasma Television
I have a 55HDS69 and the red stand-by indicator lamp flashing, No sound and no picture.. Has anyone else had this problem ? Thanks !!
Tries tv unplug,replug it back like about an hour later by letting the tv resetting itself back to the factory setting.The tv now should be working again,if not the tv still have the same problems.Mean the tv power supply board it is the causes and the problems.The tv power supply board that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 26, 2011 | Hitachi 55HDS69 55 in. Plasma Television
When i turn the power on my 55 inch plasma tv, my screen stay black no picture
If you take the back off you might see a couple of electrolytic caps that might be bulged on the power supply board. The power supply board is getting weak, and if you replace the electrolytic caps that will fix the problem. You can also replace the power supply, and you can check at www.partstore.com for a power supply.
Feb 14, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Have sound. But no picture
The Zsus and Ysus Board are common failures. It is a possibility that the Plasma Panel also is the problem. If you take the back off, (make sure unplug the set first), the board on your left is the Zsus and is marked accordingly. The Ysus is on the right of the Power supply. Look for fuses being open on the Zsus Board and Power Supply using a ohm meter. If they are, I would replace both Zsus and Ysus. They seen to fail together many times. If the fuses are good. I would suspect the Plasma Panel.
I hope this helps,
Skyassoc
Dec 10, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Power problem
Hello Aleone
you will need to take your Tv to a repair shop and have them replace the power supply.
Aug 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Jul 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55HDS69 55 in. Plasma Television Logo
1,264 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
