Question about Optoma H56 Multimedia Projector
Screen Display I instaled this unit in the ceiling yesterday and adjusted the size to fit the full screen, I removed the unit and ran the wires in a more permanent way and reinstalled. Now i cannot get the projector image to fill my scree. I have tried 4:3, 16:9, letter box, and one other. I believe the problem is with the computer as my son hooked it up to a tv while i was making the permanent installation of the projector. Help, Help, Help I have a church service in that room tonight.
    Brigadier General:
  • 3,614 Answers
TRY TO ADJUST THE SCREEN RESOLUTION OF YOUR COMPUTER. FOLLOW THHIS FEW STEPS TO MAKE CHANGES...
1.Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
2.In the Control Panel window, open Display.
Note: In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
3.In the Display Properties window, click on the Settings tab.
4.Locate the Screen resolution slider on the left-hand side of the window. Under most circumstances, the best choice is 800 by 600 pixels or 1024 by 768 pixels, possibly higher if you're using a 19" or larger monitor. The "best" setting is highly subjective to your personal preferences.
Note: Some types of software require the screen resolution settings to be set at a specific size. If you receive errors when opening certain software titles be sure to make any changes here as necessary.
5.Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
Hope this initial info helps.
Keep Us Updated on here
Posted on Nov 05, 2008
  • 749 Answers
Go to start-settings -control- panel - display - settings tab. change the desktop resolution around ( the slider that says "desktop resolution"), checking the screen as you do . this should help you find the edges of the screen.
Regards..
    President:
  • 2,712 Answers
What is the screen resolution on the computer?
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Cannot get full screen picture
Full screen resolution depends on the source signal that you feed to your LCD TV. Most often, the signal come in 16:9 screen size, which sometimes show big black portion on both top and bottom of screen. To maximizes screen display, you can adjust the screen size of your LCD TV through remote control, this features are available in most LCD TV. you will have the option to choose Full Screen Mode, 16:9 screen resolution or many others to choose from (most case about 3 to 4 screen size.
Jul 03, 2011 | Dynex DX-L32-10A 32" LCD HDTV
How to fix ps2 display settings
You can adjust screen display settings while playing PlayStation 2. Press the PS button on the Wireless Controller during gameplay and then select [Settings], adjust the following settings. Screen Mode Normal: Set to upscale and display at a size that matches the screen size. Full Screen: Set to upscale and display at full screen by changing proportions and stretching the image. This setting can be selected only when [Normal] or [Full Screen] is selected under Settings > [Game Settings] > [PS / PS2 Upscaler].
Mar 31, 2011 | Video Game Consoles & Games
How do I adjust web page to fit display screen
There is the Zoom option in the View menu if you are using IE. You can set it to 100%. With IE8 you can use F11 to set it to display on full screen. Unless you need to set the screen resolution, width and height for your monitor, those should work for you. Pressing Ctrl key and scrolling your mouse will adjust the zoom of web page too, quicker way.
Aug 18, 2010 | Microsoft Windows XP Professional
Can i adjust size of display as a cracked screen has blocked some
Hi. The best thing to do is to get an external monitor and connect it to your laptop. Press Fn+F8 to show the display on your ext monitor.
^_^
Jun 07, 2010 | Dell Latitude D600 Notebook
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
Screen adjustment of toshiba satellite 25505
There is a micro cable that runs down one side of the screen then around the hinge then under the bezel and connects to the motherboard.
If everything is fine there then follow the process mentioned below.
right click on the desktop
click on "properties"
click on "settings" tab
click on "advanced options"
click on the "monitor" tab
uncheck the box that says "hide the modes that this monitor cannot display"
if you now click the "adpater" tab and click on the button to "show all modes" a full list of all screen sizes should appear.
click "ok" to close the advanced options window
you should now be looking at the screen setting window where you can adjust the screen settings by sliding the screen resolution tab left or right to the desired scree size for installing the program.
Aug 04, 2009 | Computers & Internet
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Optoma H56 Multimedia Projector Logo
41 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
