Question about GE Profile JT912 Electric Single Oven
Clock Display I leaned against the buttons of my oven and now I have milatary time on my stove. I cant clear this. How can I get this back to standard time?
  • Dawn Tice Oct 09, 2006
    WOW! Thanks!
    President:
  • 878 Answers
Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
Posted on Oct 09, 2006
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
Lost handbook for cooker. Cant remember which
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
How do you set the clock on a stoves 059040411 oven?
I don't know what model oven this relates to, STOVES may be able to help you if you need to take this further. For the 720ef , this is what you need to do.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Stove with LED clock display, need to be set
Try holding 2 buttons at a time and whilst doing so, press the button with time on it or clock face, or just keep trying different buttons until myou get the right combination, stick with it you will get it to go.
Dec 15, 2008 | Stoves Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
GE Profile JT912 Electric Single Oven Logo
170 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
