Question about Canon XH A1 Mini DV Digital Camcorder
Playback STD Locked Playback is Restricted message
I recorded two hours of footage on my Canon XH A1 camcorder. When I simply tried to play it back on my LCD screen, the LCD screen gives the message "Playback STD Locked Playback is Restricted". Is my footage gone, or does something need to be set properly (what are the steps to set it properly) for it to playback. And yes, as you probably know, I am very new to camcorders in general. Thanks for your help.
Rob in Atlanta
  • RobBet Nov 08, 2008
    Hello, thanks for trying Snowsurfer58. I actually figured out the problem on my own. I am sure you would have too, if I had described the problem more clearer, and I apologize for that. I neglected to say that the first part of the tape I attempted to playback was playing okay. Someone (a professional) had recorded about ten minutes of footage in HDV, and that played back okay. After viewing a tutorial from VASST on how to use the Canon XH A1, I change the camcorder to record in SD mode. Well, in essence, I was attempting to playback footage recorded in SD in HDV mode. Once I got into the menu on the Canon XH A1 and went into "Signal Setup" and changed the Playback mode to DV, my footage played back fine. It's probably not a good idea to record footage in HDV and DV on the same tape, but again, I am new to all of this. Thanks again for your help and quick response.
  • 37 Answers
The tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Posted on Nov 06, 2008
I recorded 2 hours of footage this passed weekend, just as I was finishing the head cleaner warning came up. I ran the tape through. I tried reviewing my footage today with playback and it is acting like...
I've had a similar problem, the solution to mine was that one of the tape heads had moved out of position by a fraction and so it was having problems tracking back through the tape footage... if you put in a tape that you know isn't blank and press play then hold fastforward to skip through the tape can you see footage on the tape fast forwarding? If so you need an engineer to realign the tape heads for you.
Jan 04, 2010 | Canon XH A1 Mini DV Digital Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Jul 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
While trying to upload video i get std playback is locked
According to page 89 of the manual (available here), you need to set the playback standard (HDV/DV) of the camcorder to match the standard used when recording the tape. Instructions for doing this are on page 40 of the manual.
Mar 08, 2009 | Canon VIXIA HV30 DV Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
My Canon XH A1 will not turn on to record but the camera will turn on to watch playback. I need help!!!
Check your little lock and standby lever at the back of your hand strap, its likely positioned between standby and lock.
Dec 01, 2008 | Canon XH A1 Mini DV Digital Camcorder
XH-A1 Stuck in Lock Mode?
Take the camcorder apart then press the button inside it because it seems there is a plastic peice broken on the button.
Apr 10, 2008 | Canon XH A1 Mini DV Digital Camcorder
Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Jan 26, 2008 | Canon GL2 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 Mini DV Digital Camcorder Logo
5,673 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
