Question about HP Deskjet 6940 InkJet Printer
Repair damaged circuitry to black ink cartridge
I have just aquired a 6940 printer. However, there is some damage to the ribbon circuit that feeds the black print cartridge. It appears that the metal spring holding the cartridge in place has become dislodged and has pierced the ribbon circuit breaking one of the tracks. I would like to know the best/easiest way of removing this part of the circuit so that I can make repairs to it.
  • belmont31 Nov 07, 2008
    Thanks for the advice frcs68, however I have managed a repair. I was able to scrape away the top coating of the broken track thus exposing the circuit below, and using some fine copper wire and a very steady hand I was able to solder the wire across the break, and cover up the repair with some electrical tape. I was also able to do this with the ribbon still in the printer by just removing the housing for the cartridges. The printer is now working 100%
    Genius:
  • 1,605 Answers
The ribbon i sprinted on a flex. it is non-repairable.
if you want. get some of the older ribbon (used for the IDE hard drive). but you need to unsolder the connecting connector and solder the ribbon directly to the ckt board. not a easy task, specially the components and feed through is getting smaller.
Posted on Nov 07, 2008
  • Frank
    Frank Nov 07, 2008
    good deal!
Unable to clear missing/damaged cartridge msg even after cleaning.
why does my printer say ink cartridge missing or damaged ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Aug 8, 2012 - 10 posts I recently changed my ink cartridges ( colors and black) and now it says that the ... why does my printer say ink cartridge missing or damaged? ... cartridge from Office max and it still has the message and I am unable to print. ... Remove the cartridge and take a close look at the tiny circuit card on the section ...
Nov 30, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
The black ink cartridge has failed
It happens when that spring comes loose from the right side. When you get that hole, traces or wires in the ribbon cable are broken and you have to replace the entire carriage. Around $89.00
Aug 10, 2009 | HP Deskjet 6940 InkJet Printer
Check print cartridge flashing
cartridge circuitry damaged, replace with new one
May 26, 2009 | HP PSC 1401 All-In-One Printer
Printer not working
Hi I am Vortash either the printer circuit in the printer has a fault or the drivers have been corrupted or the control head is damaged or dirty .. So firstly remove the cartridge and with a small brush and some ink flush or alcahol gentley wash the cartridge holder check that the ribbon connecting it to the printer circuit is not damaged . Clean the print head ? cartridge connections with the fluid or alchahol and leave for five minutes replace and do a printer purge or clean . In add printers remove the printer that is installed and any secondry image drivers .. and rebbot the comuter follow the on screen instructions and install new drivers if you can update the latest drivers from the Epson web site then reboot again ... go to add and remove printers again and print test page or a document from your files .. if the fault has not ckeared the fault is the electronics of the printer and it will need an engineer to repair it .... Regards Vortash
Apr 25, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
I have a Deskjet 6940 printer and ive bought a HP348 photo colour ink cartridge. it wont fit in the slot!? Does it go in the colour slot?
Your printer doesnt support HP348 cartridge.
HP 99 Photo is the cartridge meant for 6940 which wud go in the slot for black cartridge. and you can print approx 130 photos .
Mar 28, 2009 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Printer Toolbox Not Recognizing New Black Ink Cartridge
Pop out the cartridge and look inside the printer where the black cartridge goes. There may be punctures in the ribbon cable from the metal wire that rests against the catridge. I have lost 2 6940's to this problem.
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
