Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Very Dark Picture
Recently the picture on this TV 'went out'. Kind of hard to describe but I can see red colors but nothing else. I tried using the 9-point convergance and all three of the colors came on and went through their routine. Occasionally the picture will work ok but most of the time it does not. One additional point, when I hit the menu button (at which point the picture shrinks and the menu pops up) the menu items appear to be 'washed out' but the picture looks ok.
    President:
  • 3,130 Answers
This sounds like a typical problem in the sweep power supply.. theres a filter capacitor for the CRT screen voltages that is most likly open or changed value. the first clue is that you get all your colors on the convergence. this is a high voltage circuit and should not be messed with by the user unless they have solid state repair exoperience and know all the high voltage saftey factors involved. Please call in a trained tech to assist you in this matter. Good Luck
Posted on Oct 08, 2006
Hi, we have a ps3 we play Black Ops on. Its connected to a Sony Trinitron tv w/composite cables. Lately, the picture has been very hazy and dark, no bright colors like it used to be. Its hard to see where...
green sounds like a TV problem if persists with other games could be TV but im kinda thinking it is ingame settings occasionally updates can reset picture settings in the game i think for black ops it had some kind of adjust brightness until you can't see this object in background and sometimes it helps to go back and check that only other explanation would be you went to different resolution ex: 480, 720(hi def), 1080(highest high def)
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Problem with the color on my TV
I will need to know what make and model your tv is.
Feb 16, 2008 | Televison & Video
convergence problem cost about 2 hundred to fix
Jan 06, 2008 | Philips 51PW9363 51" Rear Projection...
Sanyo ds31590 picture's very dark and red
sounds to me that your picture tube needs rejuvenated.
You will need to get it done by a tech.
mechanical doesn't mean a thing when it comes to electronics.
Mechanics when working on electronics, end up costing more damage when you end up taking it to a tech.
Oct 23, 2007 | Sanyo DS31590 31" TV
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
