Question about Samsung HL-S5087W DLP TV
Samsung HL-S5087W Shuts off
TV shuts off 10 secs after it is powered up and three LED flashes
  • tomandnina Mar 06, 2009
    often after being on for 1-2 mins it will shut off and it will do this a couple more times. and even hours later it will shut off each time with a buzzing noise what is wrong with my hl-s5087w ?
    New Friend:
  • 111 Answers
Check the vertical amp section
nuwan.
Posted on Jan 19, 2009
When turned on the lamp led flashes, the bulb appears to lite up but the picture can take several minutes to come on then the set works fine until shut off. please any ideas ward
If lamp has not been replaced in tv in last 2-3 years then it seems time to get it replace.
Lamp replacement procedure is easy and written in user manual of tv.
Thanks.
Jan 05, 2011 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP rear projection TV keeps shut off and won't stay on longer than 30 seconds.
your bulb has reached the end of its life (at least this is what your tv thinks) you need to replace the bulb and or make the think you did. (there is a reset in the service menu for the bulb)
Dec 14, 2010 | Samsung HL-S5087W DLP TV
I have SAMSUNG HL-S5087W that sometime shuts off several times a night. And sometimes not at all. Heard there is specific part that is not very hard to change. Any help out there?
Yes,it is the tv projection lamp.When it is shutting down several times.The LED "LAMP" light indication flashes or stay on.That the indication the projection lamp life are ending or near the end.Require a new tv projection lamp.
Dec 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLS5687W XAA will not stay on
You might have the problem with your standby processor on it, that needs samsung technicians.
May 03, 2017 | Samsung HL-S5087W DLP TV
TV shuts off randomly along with lights on front of TV
Check ur power source,like the outlet?Check change the A/C cord?Still happened it ur tv power supply board have short somewhere,must change the whole board.Intermition prob.very hard to determin to troubleshoot,by parts to parts to changes.
Nov 04, 2009 | Samsung HL-S5087W 50" HDTV
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-S5087W DLP TV Logo
369 people viewed this question
Henry  Thomas
Henry Thomas
