Question about Garden
MTD reartine tiller, wheels won't turn in or out of gear
Wheels won't turn in or out of gear. I don't know model number
  • NCKR Mar 08, 2009
    Tines are seized up. Worked great last fall, when I attempted to start and run this year the tines are seized tight. They won't move at all.
    Problem Solver:
  • 8 Answers
Broken drive blet or chain, check accordiningly
Posted on Nov 16, 2008
Mtd turf power tiller
cannot find anything about a 420 tiller... need an actual model number please
Dec 24, 2013 | Garden
I need to replace the wheel on my tiller, The pin is out. The wheel won't budge
Try using some WD-40 between the axle and wheel bearings. Let it sit for a while and then try again.
Aug 03, 2011 | Mtd Garden Tiller (Mtd)
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Mtd.tiller,pwer on wheels,but no power on tynes
If you have drive power but no till power the problem will for sure be in the gearbox. What is the model number of your tiller?
MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Mar 21, 2010 | Mtd Products Yard Machines 158CC Tiller
How to put gearbox back together on mtd reartine tiller . its apart in a box and haveing troublle with the forward and reverse gears
If you will go to the link below you should be able to find a parts diagram for your gearbox. It is about the only way to see how it all goes back together. It would be too difficult to try to walk you through it here.
http://www.milacalawn.net/mtdparts.html
Mar 13, 2010 | Mtd Garden
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
645 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
