Question about Ricoh Aficio 250 Copier
Printing from PC to Copier with USB cable
I want to print from my pc to Ricoh Aficio 200 copier with USB to Parralel cable with can not install the copier on the pc. what can be done? Have USB cable from pc connected to parralel port of copier. my computer do not have parralel connections or com connections.
Thx,
Dino
  • Ricoh Master
  • 2,794 Answers
The drivers might have a tough time recognizing a 250 as a usb device on your computer. There wasn't a USB interface created as an option on your copier. Does your copier have a network adaptor on it?
One idea that will work on your copier is a parallel print server either wired or wireless. I've done this for a few of my 220/250 customers.
Posted on Nov 05, 2008
My Ricoh Aficio 1018D Copier keeps printing on its own and it won't stop how do I reset it completely and also it says there a paper jam but there's nothing. What can I do?
Sounds like a bad print file and causing problems. First unplugged Ethernet cable from copier turn off copier look through copier and see if you can find paper then turn on copier and see what happens.
Oct 19, 2015 | Ricoh Office Equipment & Supplies
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
My printer wont print from my computer. I installed it and it recongizes the computer but it wont recieve it. It says error
Have you installed the correct drivers for printing...also you need to check the connection port.. make sure you have connected it and have it registered as connected by the correct port you can find this by going to the control panel on your computer and look for printers find your copier and right click on it .. you see apage open look for the ports tab and check that the port for the copier is set to the correct method ie usb for usb connector or parellell port TCIP if connected with a network cable..if you have it connected with a network cable you will have to enter the ip address too.
Jun 27, 2010 | Ricoh Aficio 2035 Copier
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
May 29, 2010 | Ricoh Aficio 2015 Copier
Trying to print in PDF or JPG format
no usb is not available for this copier ethernet is what you want.
Oct 26, 2009 | Ricoh Aficio 1035 Copier
If ir5000 parralel port can be use for printing from computer
If it has parallel port you must have connected it to your pc and would be using to give print cmd through pc. If not then you require installation cd to install printer driver. and enable file and printing sharing in your lan and you can give print cmd from any pc of your lan. What is your exact problem kindly let me know in detail so i can solve it.
Jun 14, 2009 | Canon imageRUNNER 5000 Copier
Copier Prints Blank Pages
My copier Mita DC 1560 prints blank. Any solution?
May 07, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 450 paper format printing problem
This could be a few things, first thing i would try is to go in page setup under the program you are using and make sure paper is set to auto select (File>page setup). The program will override the print driver.
next make sure the driver setting (paper source) are also set to auto. make these changes by right clicking on the driver>printing preferences.
third I would go to the copier, Make sure the tray are set to the proper paper size and the display paper size matches the tray
Dec 26, 2007 | Ricoh Aficio 450 Copier
Printing from PC
use parrallel cable. if there is ethernet port u can use a cross lan cable also.
Sep 02, 2007 | Ricoh Aficio 250 Copier
Ricoh Aficio 250 Copier Logo
258 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
