Question about GPS
Need to update maps for goodmans satnav - GPS
  • 2 more comments
  • Anonymous Dec 27, 2008
    need to update the map....
  • wooleydaniel Jan 04, 2009
    well the web site says that you update your map but does not show you how
  • jworner Jan 19, 2009
    anyone know where to find the updated maps for this unit?
  • marbleduffy Jan 28, 2009
    I have dowloaded the unblock software. Where can i get my map updates now ?
I need to update my Nextar X3-02 and find nothing that will help me complete the task. Please help.
Posted on Dec 03, 2008
How often should you update or is it more practicle to just purchase a new garmin every couple years?
If you're happy with the satnav you have it's cheaper to update. You have the option of buying a once off map update or a lifetime update. That is for the lifetime of the satnav not your life. With a lifetime update, which costs around 120 euros, you get 4 updates each year. This is the cheapest option. However the only problem with this method is that the maps get bigger each time you update and the space on your satnav stays the same. I started off with a full map of Europe and now I'm only able to store Western Europe on my garmin nuvi 760. You can use memory cards to hold some of the map but older garmin satnavs have a problem recognising the maps on memory cards. If you need the full map you might be better buying a new satnav every few years. If you only use part of the map a lifetime update might be the best option.
If you decide to go for a new satnav I would suggest that you go for one with the biggest storage space possible and then get a lifetime update or get a model that comes with lifetime updates like the 3790LMT. You can judge the storage size by the amount of maps it comes with. The 3790 model has the complete USA + Canada and Mexico or the 2370LT comes with maps of Europe and USA, lifetime traffic updates but not lifetime maps.
Apr 24, 2011 | Garmin nuvi 350 GPS Receiver
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
I just bought a new garmin 1300 gps love it does this model have free up date or when will it need to be up graded later.
If it's the 1300 it does not have free updates. The only time you get a free update is if a new map comes out within 60 days of your satnav first accessing satellites. If it's the 1300LMT then it does have free lifetime updates. The LMT stands for lifetime maps and traffic. Of course you're paying for the updates in the price of the satnav. (Lifetime means the life of your satnav not your life)
If yours doesn't have the LMT you can buy lifetime map updatess on the garmin website. Updates come out around 4 times each year but it's up to yourself how often you want to update. The satnav usually displays a message advising you to update when the map is a year old but it will continue to work if you don't update.
You can get information about how to update your satnav at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Apr 17, 2011 | Garmin GPS
What is the best and cheapest way ot update are garmin. or is it better to get a new one
There's only one way to update a garmin satnav without risking destroying it. You can find details of how to do so at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps. To do a once off update will cost in the region of 80 euros. To get a lifetime update will cost around 140 euros. The price varies depending on the map you want to download. This is for the lifetime of the satnav rather than your lifetime.
The nuvi 200 is a discontinued satnav, even though it may only be a few years old, and the problem with it is that it probably won't be able to hold the complete updated map. This means that you'll have to download only part of the map e.g. if you have a map of Europe you may have to settle for Western Europe or Central Europe etc. You can download the whole map to your computer and install the remainder to an SD card. However maps on an SD card rarely work with the nuvi 200.
So it depends on what you want. If you want the complete map it may be better to go for a new satnav and try to sell your old one to cover part of the cost. If you only use the satnav in your own country or state you might be happier to just update and settle for part of the map. Some new garmin satnavs come with free lifetime map updates. They can be identified by the letters LMT at the end of the model name. Of course you're paying for them in the price of the satnav. The problem with the new satnavs is that in 3 years time or so they will also be discontinued and outdated and the full maps will probably not fit on them either.
Apr 16, 2011 | Garmin nuvi 200W GPS Receiver
Hello how can I update my Carmin nuvi 660 and download the map of new zealand ? thank you
Details of how to update your garmin satnav are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
To get a new map of NZ you need to have your satnav registered. Details of how to do so are at the above link also. When you're registered go to www.garmin.com
  • Click on the myGarmin tab
  • Log in using your username and password
  • Click on the myMaps tab
There you'll see the map installed on your satnav. On the left hand side of the screen you'll see in blue writing a link saying "Shop for new maps" and then on "View additional maps for this product"
Scroll down as far as the map of NZ and select it. Follow the prompts.
If the map you already have on your satnav is not NZ and you want to save that too it's unlikely that both will fit on your satnav. If this is the case follow the instructions, at the above link, under the heading If the map is too large to install on your satnav for downloading to your computer and installing from your computer to your memory card rather than the satnav. Be advised maps installed on memory cards will not always work on garmin nuvi satnavs particularly if the memory card is larger than 2 Gb. Please read the article at the link above before buying.
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
Need to update maps for free on my garmin nuvi 2w series, what are the steps
The only time you get to update your maps for free from the garmin website is if it's a new satnav and a new map becomes available within 60 days of it first connecting to a satellite. Details on how to update your map are available at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps. If you see free maps available elsewhere be suspicious of them as they are likely to damage your satnav.
Dec 26, 2010 | GPS
I recently purchased a Garmin nuvi(r) 1310(T) from Halfords in Manchester and was advised to get a "free" update after registering my unit, as it could be 1-2 years old. On checking there were no "free"...
If a new map becomes available within 60 days of the satnav first receiving a satellite signal you get it free. If you only got the satnav there may not be an update at the moment. While the satnav may have been a while in the shop Halfords keep the maps up to date. Even if there was not a free update available myMaps in myGarmin should show if there's an update which could be paid for available. If it says no update available you probably have the latest version. A new map normally comes out in November though the dates vary. Keep a check by logging into myGarmin and checking on myMaps. When the new map becomes available it should show up there. It will let you know if it's free or not.
If you want to check what year the map on your satnav is:
Press TOOLS (the spanner symbol)
Press SETTINGS (or LOCALE if your satnav doesn't have a settings icon)
Press MAPS
Press MAP INFO at the bottom of the map page
This will show what map you have and the year of the map. If your map is the latest version it would explain why there's no updates
Oct 22, 2010 | Garmin GPS
MY MAPS HAVE GONE FROM MY SATNAV HOW DO I DOWNLOAD NEW ONES
The maps may just be unselected rather than gone. To select them press the spanner icon (Tools) then press Maps. At the bottom of the screen press Map Info and see if there's a map there. There should be a tick at the side of the map name. If there's not press the map name and the tick should appear. The map will then be selected and should be ok.
If you need to get a new map or map update connect your satnav to your computer. Go to www.garmin.com. If you have already registered your satnav click on myGarmin and then on myMaps. (Details on how to register are below) Your map should be shown there and if there's an update available click on GET UPDATE to download the updated map. If there's no update and you need to buy a new one click on Shop For More Maps and select the ones you want. Follow the prompts.
TO REGISTER YOUR SATNAV
Go to www.garmin.com and select your country. Click on myGarmin and then on Register Your Garmin Product. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you want to update your maps.
Aug 19, 2010 | Garmin StreetPilot C330 GPS Receiver
I am trying to update my garmin 255w and not getting anywhere. I have no idea what I am doing wrong. Help
To update the maps you connect the satnav to your computer. If you haven't registered your satnav already you need to do so first. Go to www.garmin.com. Select your country and then click on myGarmin. If your satnav is already registered skip to the next paragraph. If it's not registered click on Register Your Garmin Product. When registering you'll be asked to create a username and password. Write them down and keep them safe as you'll need them anytime you update your maps.
When you have registered your satnav, or if it's already registered, Click on myGarmin, enter your username and password and log in. Click on myMaps. If there's a map update available it will say so beside the map name. Click on Get Update and follow the prompts.
To update the software, connect your satnav to your computer, download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 if you haven't already done so. When it's installed it will search for updates. Follow the prompts.
Aug 16, 2010 | Garmin nuvi 255W GPS Receiver
GPS Logo
602 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
