Question about Whirlpool Duet GHW9150P Front Load Washer
Water leak at door but seems to come from door itself.
Usually happens when filling, a small stream trickles from bottom center of door, down the front of machine and eventually ends up in the drawer of pedestal, which has drain holes so ultimately on the floor. the door opening boot seems OK, and when the door is opened, water sprays out of the bottom of the door. if i swing the open door back & forth quicky, water will keep coming out of the door. is there a seal for the window in the door?
  • 63 Answers
No seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Posted on Nov 15, 2008
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
I have a Mazda B2500 (2000). Everytime it rains the drivers side floorboard gets soaked. There is no dripping or water running down the door. What could this be?
You could have a windshield that is leaking water. Often this water will trickle down from the bottom/inside of the glass and then down the firewall, under the carpet or floor mat, and to the floor. The way I usually hunt for these is to remove the floor mat or carpet then get a flashlight and lay down in the cab so you can see under the dash area while someone sprays water on the vehicle with a garden hose. Often the leak will show up as a trickle that you can then backtrack to it's source. Another spot to look for is at the cowl in front of the windshield where air for the heater and a/c is pulled into the passenger compartment. The water drain holes in this area can plug up and allow water to overflow into the passenger compartment. Good luck, hope this helps!
Apr 08, 2011 | 2000 Mazda B-Series
My washer is leaking from the front door. I see water dripping/streaming down the bottom center. Is it clogged? Bad seal? What do I look for?
I would expect that your diagnosis of clogging is correct.
There should be some drain holes in the bottom of the seal, this seems to be the most likely place.
If there is no problem there, does your door seal look worn? (Rather less likely I think).
Dec 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaks water when washing from the door
It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
Thanks.
Kevin
Jul 04, 2009 | Whirlpool Washing Machines
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
295 people viewed this question
Dan Webster
Dan Webster
Sal De
