Question about Samsung CLP 300 Laser Printer
Paper jamming and misfeeding - Samsung CLP 300 Laser Printer
  • sjmarshy Nov 18, 2008
    my printer is only a few months old and the paper feeds in at the wrong angle and crumples against the side of the printer, I was wandering if theres any way to fix this non-mechanically as if I have to I'll attempt to call in my warranty.
    cheers
  • Randy110 Feb 16, 2009
    I am having the same problem. The printer is cannon clp-300.
    Will the rollers fix the problem.
    Thanks
    Randy
  • 64 Answers
Misfeeds usauly mean worn pick up rollers. this can also cause the jammin of the paper as well if the paper is not folliwing the path correctly due to being picked from the tray at a different angle top nonmal. if you let me know the makeand/or model number of your printer i will try kfind the part numbers for you
Hope this helps
Pete
Posted on Nov 05, 2008
What is causing misfeeding?
Either the paper is slipping and not reaching the sensors at the right time. or a sensor flag is broken/missing/out/stuck and the device stops the paper thinking there's a jam. Clean all the paper feed rollers with a clean lint-free towel and water only. See if that will improve the grip of the rollers. If they appear shiny, replace the rollers. They are too worn out to continue working properly.
Feb 29, 2016 | Xerox Phaser 6360 Laser Printer
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
Paper Jam Error.. but paper jam not exist
If the jam resets after opening and closing door, then its misfeeding caused by a faulty feed clutch. Can swop it with by-pass clutch. Same thing just different colour plugs.
If it doesn't reset at all after opening or closing the right cover you either have a faulty or out of position side door micro switch that is not activating.
Or the other problem could be that the registration sensor actuator is stuck in the up position. Not moving freely.
Nov 16, 2017 | Ricoh Aficio 1013F Copier
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
Jul 26, 2011 | Lexmark X2470 All-In-One InkJet Printer
IP3500 keeps misfeeding paper, it takes it from the right hand side (looking at it) and jams everytime. It is out of warranty but has had very little use, please help!!
possibly that a foreign object, ( label, scrap of paer), has fallen down inside on the left hand side, and it not letting the feed roller catch the paper, the right roller gets it and then it jams. You can get a torch and have a look where the paper goes in to see if this is the case. Dismantling a printer is not an easy job, and it would probably be cheaper on ink to buy a new one.
Sep 17, 2010 | Canon PIXMA iP3500 Printer
Paper misfeeds inside the printer
I followed the advice of one of the posters by removing the paper and putting through a sheet of photo paper through the copier. When I noticed that the blockage was a small pebble-ish object, I poked at it with a long knife and then the photo paper helped to push it through. That did the trick!
Jul 18, 2009 | Canon PIXMA MP610 InkJet Printer
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Samsung CLP 300 Laser Printer Logo
403 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
