Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Leaks water from the bottom
My washing machine is leaking water from the bottom it is a whirpool complete care II top loader
  • 4 more comments
  • Anonymous Apr 27, 2008
    Whirlpool Ultimate Care II GSW9650LW Top Load Washer leaking
  • Anonymous Mar 16, 2014
    My machine is leaking water and I have checked all the hoses and they seem fine . The leak seems to be coming from the bottom of the machine. When I rock the bowl there is a sloshing sound . Is this residual water after washing and spin drying normal
  • Anonymous Mar 28, 2014
    water leaks from the bottom of the washing machine
  • Anonymous Mar 30, 2014
    Washing machine is leaking water from the bottom
    AA Class 6kg
  • Anonymous Apr 01, 2014
    leaking out bottom
    President:
  • 878 Answers
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Posted on Oct 09, 2006
SOURCE:
My Ultimate Care II washer starts leaking from the bottom front of the washer as soon as it starts to fill with water.
Good day,
That's almost always a bad pump. It is located in the front middle of the machine, at the bottom.
I'm enclosing a tutorial that is not limited to changing the pump, but it will get you there.
Note: The screws for the top console are located in 3 different locations. Both bottom corners, both bottom corners but hidden by two plastic end caps, and lastly, on the back.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Feb 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 6245e top loader machine does not spin or wash at all
Hope that no money is required.\
Check the drive belt between the motor and the transmission. If wet or oily or loose, correct the problem and test.
If leaking water, you may have a loose hose fitting, check them with a flashlight while running a test cycle. If not a hose, then a seal (not practical to repair yourself).
FINAL NOTE: DO NOT spend more than 75 dollars to repair a 3 year old or older washing machine. You can buy a used one that works fine for 50 to 75 dollars on Craigs List or other local web site.
Best of luck. -Jim
Oct 21, 2009 | Washing Machines
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultracare 2 washing machine leaks from bottom
one of your hoses has split or cracked or simply come loose also take lid off and check where soap drawer water pipes are
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
355 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
