Question about Arcam AVR-100 Receiver
Arcam avr-100 no power
Led light is not on and it will not turn on, tested lead and all is ok?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: We just purchased an LG,
Actually, it doesn't have ANY digital outputs. Just what do you require one for? Name specific models and functions when replying.
Do you think the TV NEEDS optical audio from the receiver? Maybe the TV could survive on just analog audio from the video source, while the GOOD audio goes to the ARCAM since the ARCAM is going to do the hard work of managing and driving the REAL speakers.
http://www.arcam.co.uk/_ugc/file/avr100e_manual.pdf
Posted on Feb 06, 2011
Using satelite speakers on arcam avr100
Depending on the type of satelite speakers, Bose for example used on their own would be damaged, if your satelite plugs into a sub speaker they are protected by circuitry that controls output level when tied into the whole system, so using them on their own is not a good idea.
Mar 30, 2012 | Arcam AVR-100 Receiver
Arcam AVR200. Buzzing sounds in all 5.1 speakers. Gets louder as volume is turned up. Tried all sorts of different things - different power source, 1 speaker, different modes.
I had the same problem. I was told by a sales guy at a high end audio store that I should try using a 3-Prong To 2-Prong Adapter. I went and bought one. I plugged it in and no more buzzing.
you can find them at HomeDepot, Lowes or dollor store.11_25_2012_6_28_23_pm.jpg
Jul 12, 2011 | Arcam AVR-200 Receiver
Hi My AVR 100 just started to smoke and then the sound went completely, think this sounds major problem........is it ?
Oh yeah, re-apply power ONLY AT YOUR OWN RISK. Get it to a competent tech to evaluate it.
Generally speaking, an amp smokes or tries to protect itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 24, 2011 | Arcam AVR-100 Receiver
We just purchased an LG, LED, LCD, TV and just realised that our existing Arcam AVR 100 does not have an optical out. Does this mean we need a new amp or are there alternative solutions? Many thanks.
Feb 06, 2011 | Arcam AVR-100 Receiver
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
Bought an avr100 no remote Anyone know a full feature replacement rermote or how to get an original?
I can fix this
What is the last thing you did before this problem started?
Bruce
Jan 13, 2011 | Arcam AVR-100 Receiver
How can you tell if a Dell power supply for a PowerEdge 2900 is good? Should the lights at least indicate when power is connected even with the PS is removed from the machine? How do you best determine if...
You cannot test the power supply on the bench just by connecting it to the mains power. You need to know which pins on the connector to activate the power supply and you need to connect a load to the power leads.
The best way to test the power supply is to leave the power unit connected to the computer power up the computer and test a spare 4 wire power connector with a multi-meter. Leave the other power leads connected to the various drivers.
If computer's power LED should light up then test the voltages.
The Red and black wire should read 5 volts.
The Yellow and black wire should read 12 volts.
If the power LED does not light up, check the mains lead in another appliance to see if the mains lead is OK.
If the mains lead is OK then most likely the switch mode power supply has died.
Dec 28, 2010 | Dell 930-Watt Power Supply
Receiver died out
Maybe a fuse in amplifier section is blown out already,caused by busted four darlington transistor or if this amplifier use a STK IC. This is the common problem of the amplifier,try to check this if ever a defected then replaced it with a identical rating.
Hope it may help you;
Regards,
VOTIT
Jan 08, 2009 | Arcam AVR-200 Receiver
Arcam avr300 intermittent problems
I had this same problem with my Arcam AVR300. I ended up shipping mine to an Arcam repair center and they repaired it and shipped it back for under $200. The problems were cracked connection on the start relay and they replaced power supply diodes. Very well worth it and now I can enjoy it again!
Jun 30, 2008 | Arcam AVR-200 Receiver
Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
Arcam AVR-100 Receiver Logo
66 people viewed this question
Top Arcam Audio Players & Recorders Experts
 Grubhead
Grubhead
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
