Question about Fuji FinePix F700 Digital Camera
Bright white light
When the camera is turned on to take pictures a bright white light is on the screen. If I take a picture and then view it, it has lines of different colors. If I view pictures already on the camera, they are fine.
    Problem Solver:
  • 6 Answers
I have had the same problem with my F-700
After calling Fujifilm Custom support here in Spain, I've noticed that camera series had a common failure at CCD SENSOR, NOT THE SCREEN.
IF THE PROBLEM IS CCD (IMAGE SENSOR) FUJIFILM WILL REPAIR IT FOR FREE!!!!
I AM NOT KIDDING. I'RECEIVED A MAIL FROM FUJI SPAIN ABOUT THAT
ALSO CHECKED THAT AT FUJIFILM USA THEY REPAIR IT FOR FREE
I guess the problem is CCD (at least in mine) because:
1- Started with
intermitent colour distorsions (dissapearing from time to time)
2- The problem became more frequent as time passed by
3- THE IMAGE IS PERFECT WHEN I PLAY PICTURES FROM THE MEMORY CARD
GOOD LUCK !
Fernando
Posted on Nov 30, 2008
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
View screen lights up but no display
if u see white screen or noisy picture on lcd and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my Fuji S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 08, 2009 | Fuji FinePix 2650 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Fuji FinePix F700 Digital Camera Logo
182 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
