Question about HP Pavilion a305w (DM181AR) PC Desktop
Packard Bell Easynote - not powering up
I know the power supply is ok as there is a pink light on next to the on/off button.
Can you help - I don't have my work backed up anywhere.
Thanks
Kerry
  • 1 more comment
  • pumpkin pie Nov 05, 2008
    Hi
    I've tried that but it hasn't made any difference - tried different plug sockets around the house too. The on/off button flashes blue when I switch it on - it usually does this when there is no power getting to it - this time there definitely is!!
    Do you think the pink light is significant as when there is no power, it is usually blue.
    Thanks for your time
    Kerry
  • pumpkin pie Nov 06, 2008
    It's on the laptop itself. The light on the power adapter is green as it always is.
    Thank you for your help - much appreciated
  • d_ja32 Nov 17, 2008
    My HP Pavillion a305w crashed, i unplugged it from the back of the computer & then replugged it in. now it doesn't power up at all. no light no nothing !!!
  • 749 Answers
If this is a notebook , hold the power button down for about 6 seconds to make sure this is not just in hibernate. Make sure it is plugged directly into the wall power outlet , not a power strip.
Some laptops have a power increase when plugged into the wall and less when running off batteries.
Posted on Nov 05, 2008
  • Jeff Strader
    Jeff Strader Nov 06, 2008
    are you speaking of the light on the power adapter or the light on the laptop?
  • Jeff Strader
    if you would give me the exact model number and make i will give you further instructions.
Disable touchpad
Hi
look for a FN + some key (F3-F12) combination to turn the touch pad off, there can also be a button next to the power button to switch touchpad on and off.
You can also try to disable it using windows itself by right clicking the touchpad software (by the system clock )and in it's settings look for an option to deactivate the internal touchpad.
Hope this helps.
Sep 03, 2014 | Packard Bell Computers & Internet
PACKARD BELL EASYNOTE SJ51. NO INVERTER VOLTAGE. ALL LEDS OK, SOUND OK, BOOTS OK, SCREEN BLACK OR POSSIBLY DIM.
Simple test: get a flashlight, go with the laptop in a dark room and point the flash light at the screen. If you see the image then indeed the inverter isn't working. of you don't see it then the data cable between the motherboard and the screen has been damaged: replace it.
If the inverter is at fault you will need to open the screen cover and check if the inverter board receives power from the motherboard: if it does you need a new inverter board
http://sparepartworld.com/display-inverter-board-for-packard-bell-easynote-sj51/product_info.php/products_id/1724545
If it doesn't then a complete testing of the motherboard will have to take place to find out why and if it can be fixed.
Aug 12, 2011 | Computers & Internet
No power with power supply plugged in
I would use a power supply tester to be certain. Voltage meters are a good indicator of weather or not the main power distribution points are working, but there are actually several points providing power.
If this still doesn't work, check the power at the battery terminals to see if the battery itself is getting any power sent to it.
Apr 30, 2010 | Packard Bell (190169) Power Supply
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
How do I know if my packard bell easynote R4250 is dead?
If the laptop is more than two years old. Time to replace the battery. The power meter is not a reliable way of seeing a bad battery. If just one of the cells in the battery is bad it will not run your laptop , and the meter still would show 100%
Jan 07, 2010 | Packard Bell Easy One Silver 2120 Notebook
How do I know if my packard bell easynote 4250 is dead?
See: http://www.fixya.com/PostAnswer.aspx?thid=3830527&prdid=249462
for the answer to your question.
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Some one has given me a Packard bell easynote C 3300, ive plugged it in the power supply but all i get is a flashing orange battery light, what is happening please
try takeing out the battery and then try pluging the main power back in and see what happens. if the orange light goes away that means your battery is no good.
thanks
hope this works for you
Aug 22, 2008 | Packard Bell Computers & Internet
POWER SUPPLY
bad abttery buy new one 1st even tho says charge dont have eneghf power in it to suport it all ok buy new try that 1st
Jan 28, 2008 | Packard Bell Easy One Silver 2101 Notebook
HP Pavilion a305w (DM181AR) PC Desktop Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
